[gdal-dev] Compilation error
Vincent Schut schut at sarvision.nl
Fri Mar 28 06:30:04 EDT 2008
gary wrote:
> I did the configure --with-fPIC, though it didn't show up as an option.
> Anyway, any idea why gdal isn't compiling?
<snip>
> /usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../lib64/crtn.o
> -Wl,-soname -Wl,libgdal.so.1 -o .libs/libgdal.so.1.12.1
> /usr/lib64/gcc/x86_64-suse-linux/4.1.2/../../../../x86_64-suse-linux/bin/ld:
> /usr/local/lib/libjasper.a(jas_image.o): relocation R_X86_64_32 against
> `a local symbol' can not be used when making a shared object; recompile
> with -fPIC
> /usr/local/lib/libjasper.a: could not read symbols: Bad value
> collect2: ld returned 1 exit status
> make[1]: *** [libgdal.la] Error 1
> make[1]: Leaving directory `/usr/local/src/gdal/gdal-1.5.1'
> make: *** [check-lib] Error 2
> suse:/usr/local/src/gdal/gdal-1.5.1 #
This means you need to compile *libjasper* with -fPIC. Otherwise gdal is
not able to link to it. I think for gdal on x86_64, -fPIC is enabled by
default.
Usually the right way to add -fPIC to a compilation process (if not
offered by configure as a --with-fpic option) is to invoke configure as
follows:
CFLAGS="-fPIC" CXXFLAGS="-fPIC" ./configure --with-your-options
configure will then pick up your custom cflags/cxxflags (in case it is
c++, don't know it -fPIC applies to that but just to be sure) and will
eventually add it's own cflags to it, thus creating makefiles that will
invoke the compiler with the -fPIC flag.
Once you have recompiled jasper with -fPIC, you can probably run make in
the gdal dir again and it will build fine (or until the next error :))
Cheers,
Vincent.
