[gdal-dev] KMZ Support in OGR?
Clay, Bruce bclay at ball.com
Fri Mar 28 13:49:43 EDT 2008
I don't know what KMZ support is in the current GDAL KML but I
downloaded the libKml package from http://code.google.com/p/libkml/ and
it has KMZ support built in.  If anyone was going to look at an update
for GDAL / OGR they might want to look at that library.  The notes on
the website indicate that libKml is "an implementation of the candidate
OGC KML 2.2 standard".
A potential snag is that the Google library is under the BSD open source
license.  I don't keep track of the differences in license types so I
can't say if one is better than the other.
Bruce
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Friday, March 28, 2008 1:24 PM
To: Simon Perkins
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] KMZ Support in OGR?
Simon,
I'm not sure whether the zip file record structure is implemented in
zlib or not. If the latter is the case implementing this would be
slightly beyond the scope of GDAL. There are several projects out
there to provide such API for various kind of languages.
Best regards,
Tamas
2008/3/28, Simon Perkins <sy at perkins.net>:
> Hi,
>  Does the OGR KML driver support reading and/or writing of KMZ files?
>  KMZ files are simply zipped KML files which allow smaller file sizes
and
>  bundling of multiple files in one package. I think that google earth
>  uses the format by default.
>  Since GDAL already includes zlib, I would think that adding support
for
>  this would be pretty simple, if it's not there already. Anyone
planning
>  on doing this?
>  Cheers,
>  Simon
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
