[gdal-dev] KMZ Support in OGR?
Brian Hamlin maplabs at light42.com
Sat Mar 29 01:40:42 EDT 2008
On Mar 28, 2008, at 10:06 AM, Simon Perkins wrote:
>  Thanks - that would seem like a good way to go in the future, though
> I don't have time to work on it myself...
that may be a common story !
the relatively light weight discussion of this that I have heard so far
basically comes to a conclusion that since OGR writes out a pretty
simple KML, its not worth doing the work of bringing in the new libkml
to do that.
Its worth noting that the Simple Features Library (that OGR is based
on) only goes so far in mapping to KML.
as for kmz, thats trivial.. just pipe the output to a zip program, y?
>  As I understand it, the BSD license allows free distribution and use
> of source code and binaries, with or without modifications. The only
> caveats are that (a) you mustn't remove the copyright notices from the
> source code, (b) you must acknowledge the copyright somewhere in the
> documentation of your library / app that uses the code, and (c) you
> mustn't assert that the author of the original code endorses the
> derived library / application. Is this compatible with the GDAL
> license? Maybe the google people would be flexible if it isn't?
>  Wouldn't this make a perfect Google Summer of Code project? Can
> someone add it to the GDAL SoC ideas page?
>  Cheers,
>  Sy
>  Clay, Bruce wrote:
> I don't know what KMZ support is in the current GDAL KML but I
> downloaded the libKml package from http://code.google.com/p/libkml/
> and
> it has KMZ support built in.  If anyone was going to look at an update
> for GDAL / OGR they might want to look at that library.  The notes on
> the website indicate that libKml is "an implementation of the candidate
> OGC KML 2.2 standard".
> A potential snag is that the Google library is under the BSD open
> source
> license.  I don't keep track of the differences in license types so I
> can't say if one is better than the other.
> Bruce
> -----Original Message-----
> From: gdal-dev-bounces at lists.osgeo.org
> [ mailto:gdal-dev-bounces at lists.osgeo.org ] On Behalf Of Tamas Szekeres
> Sent: Friday, March 28, 2008 1:24 PM
> To: Simon Perkins
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] KMZ Support in OGR?
> Simon,
> I'm not sure whether the zip file record structure is implemented in
> zlib or not. If the latter is the case implementing this would be
> slightly beyond the scope of GDAL. There are several projects out
> there to provide such API for various kind of languages.
> Best regards,
> Tamas
> 2008/3/28, Simon Perkins <sy at perkins.net> :
> Hi,
>  Does the OGR KML driver support reading and/or writing of KMZ files?
>  KMZ files are simply zipped KML files which allow smaller file sizes
> and
>  bundling of multiple files in one package. I think that google earth
>  uses the format by default.
>  Since GDAL already includes zlib, I would think that adding support
> for
>  this would be pretty simple, if it's not there already. Anyone
> planning
>  on doing this?
>  Cheers,
>  Simon
>  _______________________________________________
>  gdal-dev mailing list
>  http://lists.osgeo.org/mailman/listinfo/gdal-dev
> This message and any enclosures are intended only for the addressee.
> Please
> notify the sender by email if you are not the intended recipient.  If
> you are
> not the intended recipient, you may not use, copy, disclose, or
> distribute this
> message or its contents or enclosures to any other person and any such
> actions
> may be unlawful.  Ball reserves the right to monitor and review all
> messages
> and enclosures sent to or from this email address.
