[gdal-dev] KMZ Support in OGR?
Brian Hamlin maplabs at light42.com
Sat Mar 29 13:27:45 EDT 2008
On Mar 29, 2008, at 5:43 AM, Simon Perkins wrote:
> Brian Hamlin wrote:
>> On Mar 28, 2008, at 10:06 AM, Simon Perkins wrote:
>>>  Thanks - that would seem like a good way to go in the future,
>>> though I don't have time to work on it myself...
>> that may be a common story !
>> the relatively light weight discussion of this that I have heard so
>> far basically comes to a conclusion that since OGR writes out a
>> pretty simple KML, its not worth doing the work of bringing in the
>> new libkml to do that.
>> Its worth noting that the Simple Features Library (that OGR is based
>> on) only goes so far in mapping to KML.
>> as for kmz, thats trivial.. just pipe the output to a zip program, y?
> Well, it would be nice to have something that was integrated into OGR,
> without having to mess around with external programs.
> I think rewriting the KML driver to use the google library would be a
> great idea. The current KML driver has a number of limitations - for
> instance, it doesn't support reading of multi-geometries (though I
> think
> it will write them).
Well, this thread sort of strikes a nerve for me.. I started
volunteering on this project 6 months ago primarily to understand and
contribute to KML support. Now that 1.5 has gone final and a better KML
driver is stock with GDAL/OGR, the libkml 0.1 is available.
Through a combination of time constraints, learning curve and project
technical challenges, the reality is that the KML support is what it is
so far, including my own (well-intentioned) efforts.
<flame>You say you think it would be a great idea to add a new library
in place of most of the driver that is there, but dont have time and/or
ability to make a wiki page about that as a proposed project?</flame>
Simple Features has to map to <=> from KML to work with OGR. To do it
at the level of reliability that is expected with OGR is not trivial.
Understanding the new libkml enough to use it well is not trivial,
either.
See what I mean?
I am suggesting the very same thing as you in the long run btw - and
had to have the discussion about tradeoffs in the real world.
LibKML will:
* be guaranteed to write out KML that meets the spec, now and in the
future
* will get regular bug fixes
* be a standard API - though its far from there yet
* may have reasonable approaches to many of the more interesting KML
features
but
* libkml reading KML isnt a free ticket to using and understanding the
result of that read
* mapping Simple Features back and forth is still work to be done
* the lib is immature.. just not full-featured yet, so its services are
very limited
I think KML is strategically important in the field. Other people might
mock that a bit.. As they say, informed people may disagree.
My impression is that GDAL/OGR is a top-notch OSS project, with the
highest caliber of contributers, in a very specialized field, and that
it has all kinds of momentum with a big, active set of core committers
and very strong users. On the other hand, with so many places to work
on, there are only so many engineering hours to go around.
Who knows, maybe someone out there will fund the effort and hire to do
this? Maybe someone ought to try to make that happen? What if there was
a new driver, that was libkml from the start, borrowing heavily from
the existing driver? How much effort would that be? Who would benefit
most?
all for now
   -Brian
Brian Hamlin
ISDE5 Steering Committee
Planetwork.net
(415) 717-4462 (c)
