[gdal-dev] KMZ Support in OGR?
Christopher Condit condit at sdsc.edu
Sat Mar 29 16:04:10 EDT 2008
Thought I should chime in with a couple of thoughts here:
*) Google's libkml is not yet production ready
*) Once the KML 2.2 spec is approved by OGC I expect it to be rather
stable, so I'm not sure that switching to libkml for an evolving
standard is really going to buy OGR much.
*) It would probably be trivial to add kmz support, but as Brian
suggested why not just pipe the file to a zip command?
In my mind, OGR has always been about feature data, and less about
formatting. KML is inherently about formatting. It strikes me that the
KML output driver is doing its job just fine. OGR does not make use of
many KML features aside from the geometries. All the camera angles, etc,
are of no concern. If anything, I think time should be spent developing
example xsl scripts to add formatting to OGR KML (I'll try and post some
examples to the wiki later) and enhancing the reader support. There's no
reason that the existing read driver can't do its job just slightly
better...
And as Joel Spolsky says:
http://www.joelonsoftware.com/articles/fog0000000069.html
-Chris
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Simon Perkins
Sent: Saturday, March 29, 2008 12:16
To: Brian Hamlin
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] KMZ Support in OGR?
Brian Hamlin wrote:
> <flame>You say you think it would be a great idea to add a new library
> in place of most of the driver that is there, but dont have time
> and/or ability to make a wiki page about that as a proposed
> project?</flame>
Well, that at least is one thing I have the time to fix... I've added an
enhanced KML driver using the Google library to the GDAL SoC ideas page.
Feel free to edit!
http://trac.osgeo.org/gdal/wiki/SummerOfCode
Cheers,
Simon
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
