[gdal-dev] Build process is hanging on windows
Andrey Kiselev dron at ak4719.spb.edu
Mon Mar 31 06:26:09 EDT 2008
On Sun, Mar 30, 2008 at 08:15:32PM +0100, Joaquim Luis wrote:
> I'm having the error near the end of the building.
>        cd frmts
>        nmake /nologo /f makefile.vc plugindirs
>        for %d in (  ) do  cd %d  && nmake /nologo /f makefile.vc
> plugin  && cd
> NMAKE : fatal error U1077: 'for' : return code '0x160178'
> Stop.
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> .NET 2003\
> VC7\BIN\nmake.exe"' : return code '0x2'
> Stop.
> Apparently the problem is due to $(PLUGINDIRLIST) being empty at
> plugindirs:
>    for %d in ( $(PLUGINDIRLIST) ) do \
>        cd %d \
>        && $(MAKE) /f makefile.vc plugin \
>        && cd ..
Joaquim,
I have commited the fix for this though I can't reproduce the problem.
It is probably related to the particular shell version you are using.
What is your build environment (Windows and MSVC versions)?
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
