[gdal-dev] Urgent :: gdal_translate Solution
Mateusz Loskot mateusz at loskot.net
Mon Mar 31 08:45:11 EDT 2008
SriRam Prasad Bhasker wrote:
> Hi.
> Whenever i use Gdal_Translate with the below Syntax the Monochrome 1 BIT
> image is getting converted tgo 8 BIT Image.
> Is there any Way to ensure the BPP values [Bits per Pixel] value remain
> the same even after translation.
Yes. Please, check the manual at
http://gdal.org/frmt_gtiff.html
and read about NBITS
> gdal_translate -of gtiff -co Compress=LZW input.tif output.tif
gdal_translate -of gtiff -co Compress=LZW -co "NBITS=1" input.tif output.tif
p.s. Using "urgent" in the subject is unnecessary
Greetings
Mateusz Loskot
http://mateusz.loskot.net
