[gdal-dev] ogr2ogr, shapefile 2 postgis
Roger André randre at gmail.com
Thu May 1 17:21:09 EDT 2008
Hi Paal,
I think you may need to create the PostGIS database with the encoding set
explicitly to 1252.
You can do that in the pgsql command line with, "createdb --encoding WIN1252
new_db".
Roger
On Thu, May 1, 2008 at 2:09 PM, Paal Sund <paalsund at gmail.com> wrote:
> Hi,
> I am getting the following error while loading a shapefile to postgis
> using ogr2ogr interactively from 'DOS' command window (cmd):
> ogr2ogr -f "PostgreSQL" -a_srs "EPSG:32633" PG:"<some values>"
> 33_n5000_bygg_punkt.shp -nln n5000_bygg_pun
> ERROR 1: INSERT command for new feature failed.
> FEIL: invalid byte sequence for encoding "UTF8": 0x86
> HINT: This error can also happen if the byte sequence does not match the
> encoding expected by the server, which is controlled by "client_encoding".
> Command: INSERT INTO "n5000_bygg_pun" (wkb_geometry , "area", "perimeter",
> "kupu
> nkt_", "kupunkt_id", "objtype", "ptema", "tett_id", "navn", "fyr_id",
> "oppdatert
> ") VALUES (GeomFromEWKT('SRID=32768;POINT (897350 7911435)'::TEXT) ,
> 0.00000, 0.00000, 11, 503, 'Tettsted', 4007, 860
> 2, 'Honningsvåg', 0, 20010301)
> ERROR 1: Terminating translation prematurely after failed
> translation of layer 33_n5000_bygg_punkt
> My ogr2ogr is from the latest FWTools, running on Windows XP 2002 sp2.
> My PostGIS is from the latest windows binaries (postgresql 8.3 and the
> application stack builder)
> Any clues? The error message seems to point in the encoding direction. My
> shapefile has 1252 encoding.
> I havent done anything with encoding stuff in postgrsql.
> Help appreciated,
> best Pål Herman
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080501/b5923422/attachment.html
