[Gdal-dev] VS.NET 2005 - Bulding libecwj2-3.3 from source
Mateusz Loskot mateusz at loskot.net
Mon May 5 11:05:28 EDT 2008
Maksim Sestic wrote:
> Hi all,
> I'm trying to figure out how to build libecwj2-3.3 from source,
 > using VS.NET 2005.
Maksim,
There is not such compiler. There is Visual Studio .NET 2003 (Visual C++
7.1) or Visual Studio 2005 (Visual C++ 8.0).
So, which one you use?
> Source archive downloaded from ERMapper site is
> ImageCompressionSDKSourceCode3.3Setup_20070509.zip. Since C/C++ is not my
> native dev platform, I'm stuck with compiler reporting missing winhttp.h
> header file.
Have you installed Microsoft Platform SDK?
Please, give the exact command you used and I'll try to
reproduce it and see if works for me.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
