[gdal-dev] offset and scale
Trent M Hare thare at usgs.gov
Mon May 5 15:22:19 EDT 2008
I have a set of existing 16bit geoTiffs.  While converting there was no
"Offset" or "Scale" in the converted image. I now need to add a Offset and
Scale values postmortem such that at least the label is correct.  Is there
a clever way to do this on the existing images or even maybe via a created
VRT format and a convert again?
thanks,
Trent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080505/deb97322/attachment.html
