[gdal-dev] OGR Multiple features to Shapefile
Andrea Battisti battisti at actgate.com
Wed May 7 14:06:57 EDT 2008
Hi all,
are the OGRMulti{ LineString | Point | Polygon } geometries supported by
the ESRI Shapefile driver (in creation mode?); if so I am probably
missing something in the way they should be used.
I am asking this because when I try to write such features (i.e. an
OGRMultiPoint) to a shapefile I get a crash when calling the
addGeometry() method.
I was looking for a working example of OGRMulti* features creation, but
couldn't find one.
Example code:
  const char *pszDriverName = "ESRI Shapefile";
  OGRSFDriver *poDriver;
  OGRRegisterAll();
  poDriver =
OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName( pszDriverName );
    OGRDataSource *poDS;
poDS = poDriver->CreateDataSource( "multi_out.shp", NULL );
    OGRLayer *poLayer;
    poLayer = poDS->CreateLayer( "poly_out", NULL, wkbMultiPoint,
NULL );
	OGRFeature *poFeature;
	OGRGeometry * the_geom = NULL;
	poFeature = OGRFeature::CreateFeature( poLayer->GetLayerDefn() );
	OGRMultiPoint * dpoly = new OGRMultiPoint();
	OGRPoint * point = new OGRPoint();
	point->setX( 42.0 );
	point->setY( 42.0 );
	dpoly->addGeometryDirectly( point );
	// delete point;
	the_geom = dpoly;
	poFeature->SetGeometry( the_geom );
	delete the_geom;
	if( poLayer->CreateFeature( poFeature ) != OGRERR_NONE )
		printf( "Failed to create feature in shapefile.\n" );
		exit( 1 );
	OGRFeature::DestroyFeature( poFeature );
	OGRDataSource::DestroyDataSource( poDS );
Thanks in advance!
Best Regards,
Andrea Battisti
Applied Coherent Technology Corp.
