[gdal-dev] OGR Multiple features to Shapefile
Andrea Battisti battisti at actgate.com
Wed May 7 15:20:19 EDT 2008
> Andrea,
> Yes, the shapefile driver should support all these types in
> when creating.  Your code looks fine.  The only reason I can
> think of for why this might be failing is if you are building
> on Win32 and you have a distinct heap for your application and
> for GDAL in which case there could be a problem with the OGRPoint
> you create in the application being destroyed on the GDAL heap.
Thanks for the quick reply,
I am building the test app on linux, but I saw the same problem on
win32.
Yes, as you suggest, there might be a problem with memory, because if I
create the geometry object without using the "new" operator, then it
works, i.e.:
/* working: */
#include "ogrsf_frmts.h"
int main()
	OGRMultiPoint dpoly;
	OGRPoint * point = new OGRPoint();
	point->setX( 42.0 );
	point->setY( 42.0 );
	OGRPoint * point2 = new OGRPoint();
	point2->setX( 4242.0 );
	point2->setY( 4242.0 );
	dpoly.addGeometryDirectly( point );
	dpoly.addGeometryDirectly( point2 );
/* segfaulting: */
int main()
	OGRMultiPoint * dpoly = new OGRMultiPoint();
	dpoly->addGeometryDirectly( point );
	dpoly->addGeometryDirectly( point2 );
Thanks,
Andrea Battisti
Applied Coherent Technology Corp.
