[gdal-dev] Using Ticket status request
Mateusz Loskot mateusz at loskot.net
Thu May 8 06:36:45 EDT 2008
Lucena, Ivan wrote:
> Mateusz,
> In FogBugz there is a configuration option that you can set all new
> "cases" to the administrator, in case no name was assigned. I do you
> think that trac has the same feature? But then *you* will be the
> distributor of bad news "I've got a bug!" by going there and
> assigning it to somebody else.
> Just a suggestion.
Ivan,
I don't know FogBugz.
I'm just asking developers to remember that if attempt to work on
particular ticket, just check Assign button and submit.
Mateusz Loskot
http://mateusz.loskot.net
