[gdal-dev] OGR / OSEO build info
Mateusz Loskot mateusz at loskot.net
Thu May 8 17:37:08 EDT 2008
Clay, Bruce wrote:
> Mateusz:
> Thanks for your reply.
>   I did not go back and try release mode yet.  I do most of my work in
> debug mode and rarely get a chance to go back to build a release version
> of things.  Things change too fast to lock thing down.
Understood.
> I suspect the original problem is the mixture of debug and release
> libraries because I was getting a warning about MSVCRT during the link
> process.  That usually comes up either from a release vs. debug problem
> or from static vs. dynamic library loading.
Yes, libraries mismatch is likely the source of problems.
> Either way, the OSEO makefile seems to be geared towards VS 2003 (7.1)
> so I had to make some changes for that.
OK.
Greetings
Mateusz Loskot
http://mateusz.loskot.net
