[gdal-dev] CALS Group 4
Lucena, Ivan ivan.lucena at pmldnet.com
Fri May 9 10:29:14 EDT 2008
Hi Roman,
Good source of information in file formats, in case you want to develop
a GDAL driver, can be found at: http://www.fileformat.info/format/cals/
You can also setup a VRT description file
(http://www.gdal.org/gdal_vrttut.html) in some cases.
Best regards,
Ivan
PS. Any connection with Dmitry Fedorov?
"Automatic Registration and Mosaicking System for Remotely Sensed
Imagery" Dmitry Fedorov, Leila M.G. Fonseca, Charles Kenney, B.S.
Manjunath [http://regima.dpi.inpe.br/publications/spie_fedorov.pdf]
Roman Fedorov wrote:
> Good day everybody!
> I wanted to ask if GDAL supports image formats  CALS Group 4 (.cal .ras .mil .rst .cg4 .gp4 .cals) ?
> Best Regards,
> Roman Fedorov
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
