[gdal-dev] Smoothing polygons
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 12 18:38:09 EDT 2008
Have you considered using a convex hull to merge the results.
-Steve
Clay, Bruce wrote:
> With the help of some folks on this forum I have successfully managed to
> create polygons that represent the coverage area of a set of geo-data
> points.  The operation does quite smoothly and fairly fast.  I am don’t
> to one final operation that I have searched both GDAL/OGR and GEOS API
> and have not found.
> Before I start coding I wanted to ask if anyone knows of an existing
> operation that I missed that will smooth the edges and simplify the
> resultant polygons.  The attached files show the buffered points as
> overlapping polygons and the final merged polygon.  The merged set is a
> result of applying a buffer to a GeometryCollection.  If the images make
> it though the mail filters you can see that the edges of the polygons
> have a scalloped effect.  If I can smooth the edged it should reduce the
> stored geometry size.
> Any thoughts would be greatly appreciated.
> Bruce
> This message and any enclosures are intended only for the addressee.  Please
> notify the sender by email if you are not the intended recipient.  If you are
> not the intended recipient, you may not use, copy, disclose, or distribute this
> message or its contents or enclosures to any other person and any such actions
> may be unlawful.  Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
