[gdal-dev] creating multi banded imagery
Lucena, Ivan ivan.lucena at pmldnet.com
Wed May 14 07:13:47 EDT 2008
Matt,
If you try BigTiff, GeoTiff with recent improvements, you can also
archive what you are looking for but the resulting files will not be
supported by softwares that are not updates for BigTiff. I asked some
software vendors about that and they said that are planning to support
BigTiff in about a year or more.
Best regards,
Ivan
Matt Klaric wrote:
>> Date: Mon, 12 May 2008 18:50:43 -0600
>> From: Jared Rubin <JARED.RUBIN at saic.com>
>> Subject: Re: [gdal-dev] creating multi banded imagery
>> To: "Lucena, Ivan" <ivan.lucena at pmldnet.com>
>> Cc: gdal-dev at lists.osgeo.org
>> Message-ID: <200805121850.43519.rubinj at nemesis.tucson.saic.com>
>> Content-Type: text/plain;  charset="iso-8859-1"
>> Ivan,
>> understood. i already tried NITF.
>> But i would expect that the gdal driver has some basic driver format that
>> allows for unlimited number of bands.
> Check out the Erdas Imagine (aka HFA) format.  It allows for an
> arbitrary number of bands and doesn't have a file size limit. While, I'm
> sure there is a limit, we've used images that have 14 bands. Also,
> there's no file size limit that comes along with some other formats.
> (Although, for images greater than 2GB, a spill file will be used.)
> --Matt
> gdal-dev mailing list
