[gdal-dev] gdal_merge segfaults
Wed May 14 10:59:24 EDT 2008
Peter Vogt wrote:
> Hi,
> I have gdal-1.5.1 installed from rpm in PCLinuxOS and things work ok
> besides that when trying to merge 3 files (part1/2/3.tif) with :
> gdal_merge.py -v -o test.tif part*.tif
> gdal_merge.py starts fine but then segfaults after the first image.
> I tested the same files & command on a RedHat 5 machine where gdal1.5.1
> was installed from source and there everything worked fine.
> I finally managed to get a gdal1.5.1 source install up on my PCLOS
> machine but still had the same segfault for gdal_merge.py. After some
> search in Google I now suspect that this is related to the Python
> distribution which in RedHat is version 2.3.4 and in PCLOS is 2.4.3. A
> Python update to 2.4.5 did not change anything.
> I finally ended up installing FWTools which compiles its own
> gdal_merge.py. The one in FWTools works fine and uses its own Python
> environment of version 2.2.
> So in short I have for gdal_merge.py
> - Python 2.3.4 or Python 2.2 (FWTools) works perfectly fine
> - Python 2.4.3 or higher works but then segfaults
> Can you give me any hint to find the source of the problem?
Peter,
I can't think of any reason that gdal_merge.py would be particular
about the version of Python.  I'm not sure how we would track down
this problem without having direct access to your machine to debug
things.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
