[Gdal-dev] ERDAS img format from gdal rpm
pvandeus Paul_VanDeusen at uml.edu
Fri May 16 13:26:23 EDT 2008
The gdal rpm doesn't include the ERDAS .img format.
Is there a way to add this that doesn't involve compiling gdal.
We are using the grass rpm on Fedora 8.  I'm afraid that compiling gdal
would then require me to
compile grass.  It's so easy to use the rpm's that I hate to return to
compiling grass and gdal again.
This is the gdal rpm that I have.
gdal-1.4.2-3.fc8
grass rpms are
grass-6.2.2-2.fc8
grass-libs-6.2.2-2.fc8
View this message in context: http://www.nabble.com/ERDAS-img-format-from-gdal-rpm-tp17280107p17280107.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
