[gdal-dev] gdal_grid: taking a value from feature attribute
Sat May 17 12:03:05 EDT 2008
Andrey Kiselev wrote:
> Folks,
> I need an advise. I have added a possibility to get the value for
> interpolation from feature attribute instead of Z coordinate of geometry
> record. But there is a small problem with gdal_grid utility interface.
> The "-a" option that I would like to use to specify attribute name is
> already taken by an algorithm parameter (see
> http://www.gdal.org/gdal_grid.html manual page for details). Other GDAL
> utilities (gdal_rasterize, gdal_contour) use "-a" option to set the
> attribute name. I would like to be consistent and go with "-a" too and
> rename the "algorithm" option in something other. Let it be "-m"
> (m[ethod]).
> So my question is: will it be harmless to change the gdal_grid
> interface in that way? Any objections?
Andrey,
Consistency and backward compatability are virtues.
If you are willing to do a bit of extra work I would suggest that
the argument to -a be treated as an attribute name, but if it is not
found *and* matches an algorithm name it be used as the algorithm with
a warning so folks get used to use the new algorithm flag.
Generally speaking I am loath to change commandline arguments because it
breaks scripts.  With gdal_grid you at least have the situation that the
program is very new, so it will likely not be "deeply baked" into many
scripted systems yet.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
