[gdal-dev] ogr.BuildPolygonFromEdges as called from python segfaults
David Fuhry dfuhry at acm.org
Sat May 17 23:01:02 EDT 2008
The script works fine in 1.4.4, so the problem was introduced somewhere
between there and 1.5.1.
-Dave
David Fuhry wrote:
> ogr.BuildPolygonFromEdges as called from python is always throwing an
> exception for me, and perhaps always segfaulting:
> $ ./test_build_poly.py
> BuildPolygonFromEdges failed.
> Segmentation fault
> I first experienced the error running swig/python/samples/tigerpoly.py
> on some TIGER data.  I duplicated some of tigerpoly.pl into a reduced
> python testcase (attached).
> Tested with both svn head and 1.5.1, on both RHEL4 x86_64 and Debian
> x86_64.  I don't know the debugging procedure for tracing python calls
> into C++.  Suggestions on that or how to fix the bug welcome.
> Thanks,
> Dave
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
