[gdal-dev] INST_DATA and 1.5.2
Dylan Beaudette dylan.beaudette at gmail.com
Mon May 19 13:38:49 EDT 2008
On Monday 19 May 2008, Frank Warmerdam wrote:
> >> Folks,
> >> I would like to bring everyone's attention to an unfortunate problem in
> >> GDAL 1.5.0.  It seems an upgrade in the version of autoconf used to
> >> generate the configure script has resulted in the GDAL data files
> >> getting installed (by default) in $prefix/share instead of
> >> $prefix/share/gdal.
> >> I have corrected this now in svn trunk and 1.5 branch.
> >>    http://trac.osgeo.org/gdal/ticket/2382
> >> Also, I am interested in issuing a 1.5.2 GDAL release this week or early
> >> next.  I would like to prepare a release candidate tomorrow.  Is anyone
> >> aware of critical fixes that should be done before a 1.5.2 release?
> >> Best regards,
> > Thanks for the update Frank. Will this cause any hickup when we install
> > the latest version of trunk? i.e. will paths need to be reset or the
> > like.
> Dylan,
> I don't think it should cause a problem.
>  > Also is
> > there a general approach to removing the accidentally placed GDAL support
> > files in $prefix/share/ ?
> rm /usr/local/share/*.*
> might do it as long as there isn't anything else there.
> > Also, would these misplaced files have affected any datum shifting or
> > other operations that rely on these files?
> Possibly, though I suspect that the INST_DATA location is getting built
> into GDAL so the files were being searched for in their alternate location.
> What you *shouldn't* do is take an existing GDAL build of 1.5.0 or 1.5.1
> and move the .csv files into /usr/local/share without rebuilding the
> software with the new data location.
> Best regards,
Thanks for the tips. Is there a simple way to have GDAL check to see if all of
its supporting files are intact?
Cheers,
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
