[gdal-dev] ogrinfo on JOINed layer empty
    William Kyngesburye
    woklist at kyngchaos.com
    Mon May 19 17:36:27 EDT 2008
On May 19, 2008, at 4:14 PM, Frank Warmerdam wrote:
> 2) You aren't passing the SQL statement you want evaluated using the
> sql
> commandline switch.  Try:
> ogrinfo -al -so . -sql "SELECT * ...'
Ah, that did it.  I guess the documentation is a little confusing - I
wouldn't expect a command switch to be interchangable with a layer
specification.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole.  Now what
does that remind me of?  Ah, yes - life."
- Marvin
