[Gdal-dev] ERDAS img format from gdal rpm
pvandeus Paul_VanDeusen at uml.edu
Tue May 20 15:43:37 EDT 2008
This format is available in the gdal rpm for Fedora 9.
pvandeus wrote:
> The gdal rpm doesn't include the ERDAS .img format.
> Is there a way to add this that doesn't involve compiling gdal.
> We are using the grass rpm on Fedora 8.  I'm afraid that compiling gdal
> would then require me to
> compile grass.  It's so easy to use the rpm's that I hate to return to
> compiling grass and gdal again.
> This is the gdal rpm that I have.
> gdal-1.4.2-3.fc8
> grass rpms are
> grass-6.2.2-2.fc8
> grass-libs-6.2.2-2.fc8
View this message in context: http://www.nabble.com/ERDAS-img-format-from-gdal-rpm-tp17280107p17349059.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
