[gdal-dev] GDAL and strange HDF4 dataset.
Mario Cavicchi cavicchi at ferrara.linux.it
Thu May 22 07:59:37 EDT 2008
Hi all,
I have a little problem with gdal_translate and HDF4.
I have one particular dataset that if I try to extract a band with
gdal_translate uses too much time.
I tried to open this dataset with ENVI, and the time for opening is like
for another dataset. Also with HDFview, the opening of the dataset is fast.
I don't understand where this particular dataset is different to another
dataset.In attachment of this mail the output of gdalinfo.
Someone can help me?
thanks,
regards
Ciao,
         Mario
[ Web Info: http://members.ferrara.linux.it/cavicchi ]
Driver: HDF4/Hierarchical Data Format Release 4
Files: TDS_MYD021KM_04_delay.hdf
Size is 512, 512
Coordinate System is `'
Metadata:
  HDFEOSVersion=HDFEOS_V2.9
  HDFEOS_FractionalOffset_10*nscans_MODIS_SWATH_Type_L1B=0
  HDFEOS_FractionalOffset_Max_EV_frames_MODIS_SWATH_Type_L1B=0
  LOCALGRANULEID=MYD021KM.A2006137.1120.005.2007108144937.hdf
  PRODUCTIONDATETIME=2007-04-18T14:49:38.000Z
  DAYNIGHTFLAG=Day
  REPROCESSINGACTUAL=processed once
  REPROCESSINGPLANNED=further update is anticipated
  SCIENCEQUALITYFLAG=Not Investigated
  AUTOMATICQUALITYFLAGEXPLANATION=not being investigated
  AUTOMATICQUALITYFLAG=Suspect
  QAPERCENTMISSINGDATA=0
  QAPERCENTOUTOFBOUNDSDATA=41
  QAPERCENTINTERPOLATEDDATA=0
  PARAMETERNAME=EV_1KM_RefSB
  QAPERCENTOUTOFBOUNDSDATA=0
  QAPERCENTINTERPOLATEDDATA=1
  PARAMETERNAME=EV_1KM_Emissive
  EQUATORCROSSINGDATE=2006-05-17
  EQUATORCROSSINGTIME=12:02:32.944327
  ORBITNUMBER=21469
  EQUATORCROSSINGLONGITUDE=-157.283894417366
  VERSIONID=5
  SHORTNAME=MYD021KM
  INPUTPOINTER=MYD01.A2006137.1115.005.2007108140225.hdf, MYD01.A2006137.1120.005.2007108140327.hdf, MYD01.A2006137.1125.005.2007108142554.hdf, MYD02_Reflective_LUTs.hdf.V5.0.7.11, MYD02_Emissive_LUTs.hdf.V5.0.7.11, MYD02_QA_LUTs.hdf.V5.0.7.11
  GRINGPOINTLONGITUDE=41.2891701707359, 18.4128884652194, 10.8506425178714, 38.7658086352101
  GRINGPOINTLATITUDE=25.8936929597688, 22.6128898150147, 39.9419095929572, 44.23727415488
  GRINGPOINTSEQUENCENO=1, 2, 3, 4
  EXCLUSIONGRINGFLAG=N
  RANGEENDINGDATE=2006-05-17
  RANGEENDINGTIME=11:25:00.000000
  RANGEBEGINNINGDATE=2006-05-17
  RANGEBEGINNINGTIME=11:20:00.000000
  PGEVERSION=5.0.7
  ANCILLARYINPUTPOINTER=MYD03.A2006137.1120.005.2006138185801.hdf
  ANCILLARYINPUTTYPE=Geolocation
  ASSOCIATEDSENSORSHORTNAME=MODIS
  ASSOCIATEDPLATFORMSHORTNAME=Aqua
  ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
  AveragedBlackBodyTemperature= 284.99
  AveragedMirrorTemperature= 273.15
  AveragedFocalPlane1Temperature= 267.86
  AveragedFocalPlane2Temperature= 268.01
  AveragedFocalPlane3Temperature=  82.97
  AveragedFocalPlane4Temperature=  82.85
  CalibrationQuality=marginal
  MissionPhase=EXECUTION
  NadirPointing=Y
  NORTHBOUNDINGCOORDINATE=43.9759246577512
  SOUTHBOUNDINGCOORDINATE=22.6283401988233
  EASTBOUNDINGCOORDINATE=41.0184036764234
  WESTBOUNDINGCOORDINATE=10.9920542478145
  ALGORITHMPACKAGEACCEPTANCEDATE=2002-02-12
  ALGORITHMPACKAGEMATURITYCODE=OPERATIONAL
  ALGORITHMPACKAGENAME=MODIS Level 1B Algorithm Package
  ALGORITHMPACKAGEVERSION=5.0.7.11_Aqua
  INSTRUMENTNAME=Moderate Resolution Imaging SpectroRadiometer
  PROCESSINGCENTER=MODAPS
  DESCRREVISION=5.0
  PRODUCTIONHISTORY=PGE02:5.0.7.11;PGE01:5.0.21
  LONGNAME=MODIS/Aqua Calibrated Radiances 5-Min L1B Swath 1km
  PROCESSINGENVIRONMENT=Linux minion5042 2.6.8.1-26mdksmp
  Number of Scans=204
  Number of Day mode scans=204
  Number of Night mode scans=0
  Incomplete Scans=0
  Max Earth View Frames=1354
  %Valid EV Observations=100, 98.97012, 99.99876, 99.99722, 99.99999, 100, 99.99998, 94.75074, 91.66695, 64.32755, 52.43024, 44.80312, 32.53617, 9.235164, 32.97398, 1.534053, 29.33986, 28.46012, 97.91616, 100, 99.90786, 99.99957, 99.95322, 99.9954, 100, 100, 100, 99.99996, 100, 100, 100, 100, 100, 100, 100, 100, 100, 100
  %Saturated EV Observations=0, 1.02988, 0.001239972, 0.002778623, 9.050887e-06, 0, 1.810177e-05, 5.007132, 8.327685, 35.67244, 47.56976, 55.19688, 67.46383, 90.76484, 67.02602, 98.46595, 70.66013, 71.53988, 2.08384, 0, 0.09213804, 0.0004344426, 0, 0.004597851, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % L1A EV All Scan Data are Missing=0
  % L1A EV RSB DN Not in Day Mode=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % L1A EV DN Missing Within Scan=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % Dead Detector EV Data=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % Sector Rotation EV Data=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % Saturated EV Data=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1.056691, 1.393113, 1.380622, 1.349125, 1.295725, 1.206574, 1.104751, 1.050084, 1.028724, 0.9855512, 0.9307028, 0.9181221, 0.8707859, 0.8488827, 0.8478872, 0.8500594, 0.8269796, 0.8411895, 0.7962066, 0.8337678, 0.8413705, 0.8469821, 0.8385648, 0.8827331, 0.8747683, 0.9164024, 0.8695188, 0.9439171, 0.9493476, 0.9154068, 1.013247, 1.092261, 1.075426, 1.139688, 1.185395, 1.251557, 1.255901, 1.311021, 1.435561, 1.140593, 0.001991195, 0.002172213, 0.000724071, 0.0005430533, 0.0005430533, 0.00162916, 0.002534249, 0.002172213, 0.001810178, 0.001086107, 0.0005430533, 0.0001810177, 0.0003620355, 0.001086107, 0.001810178, 0.000724071, 0.001086107, 0.0009050888, 0.001448142, 0.001448142, 0.004344426, 0.003077302, 0.002715266, 0.001991195, 0.003620355, 0.003439337, 0.00325832, 0.003439337, 0.003620355, 0.001448142, 0.001991195, 0.001086107, 0.0005430533, 0.002534249, 0.003982391, 0.002534249, 0.001991195, 0.002353231, 0.003620355, 0.003982391, 0.0001810177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.0001810177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.0001810177, 0, 0, 0, 0, 5.088771, 5.016364, 4.99066, 5.020346, 4.997538, 4.956628, 4.902323, 4.995728, 4.997176, 5.105787, 8.417326, 8.394156, 8.317404, 8.231239, 8.170418, 8.192501, 8.272874, 8.32754, 8.45715, 8.496249, 35.64529, 35.51062, 36.02905, 35.82812, 36.04353, 35.86215, 35.77707, 35.79952, 35.04902, 35.18008, 47.61057, 47.78615, 47.67139, 47.55047, 47.52187, 47.41507, 47.6522, 47.44439, 47.44475, 47.60079, 55.7274, 55.60974, 55.51995, 55.40338, 54.88531, 54.93092, 54.92332, 54.93129, 55.09818, 54.93925, 68.03262, 67.96565, 67.78463, 67.31471, 67.4273, 67.03486, 67.39617, 67.22131, 67.24013, 67.22094, 90.02158, 90.4314, 90.27464, 89.96329, 90.08675, 90.93934, 91.28219, 90.98206, 91.1685, 92.49863, 67.83858, 67.59782, 67.21153, 67.22818, 66.68259, 66.56566, 66.80605, 66.6902, 66.86144, 66.77818, 98.71839, 98.83642, 98.5667, 98.46171, 98.45158, 98.21697, 98.22132, 98.52543, 98.13696, 98.52398, 71.07843, 70.98322, 70.72255, 70.76527, 70.57701, 70.53284, 70.46188, 70.45356, 70.41554, 70.61105, 71.92849, 71.71236, 71.59397, 71.56573, 71.57225, 71.52409, 71.33186, 71.40354, 71.43323, 71.33331, 2.041518, 2.087135, 2.104874, 2.048759, 2.045139, 2.056362, 2.059982, 2.075187, 2.142164, 2.177282, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.09630144, 0.09774959, 0.0937672, 0.09014684, 0.0937672, 0.06987286, 0.08725056, 0.08182003, 0.08725056, 0.1234541, 0.000724071, 0.000724071, 0, 0, 0.0003620355, 0, 0.0003620355, 0.000724071, 0, 0.001448142, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.002172213, 0.003982391, 0.004706461, 0.005068497, 0.003620355, 0.006154604, 0.004706461, 0.003982391, 0.006878674, 0.004706461, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % TEB EV Data With Moon in SVP=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % EV Data Where Cannot Compute BG DN=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % RSB EV Data With dn** Below Scale=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.0003620355, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % EV Data Where Nadir Door Closed=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  % EV Data Not Calibrated=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1.056691, 1.393113, 1.380622, 1.349125, 1.295725, 1.206574, 1.104751, 1.050084, 1.028724, 0.9855512, 0.9307028, 0.9181221, 0.8707859, 0.8488827, 0.8478872, 0.8500594, 0.8269796, 0.8411895, 0.7962066, 0.8337678, 0.8413705, 0.8469821, 0.8385648, 0.8827331, 0.8747683, 0.9164024, 0.8695188, 0.9439171, 0.9493476, 0.9154068, 1.013247, 1.092261, 1.075426, 1.139688, 1.185395, 1.251557, 1.255901, 1.311021, 1.435561, 1.140593, 0.001991195, 0.002172213, 0.000724071, 0.0005430533, 0.0005430533, 0.00162916, 0.002534249, 0.002172213, 0.001810178, 0.001086107, 0.0005430533, 0.0001810177, 0.0003620355, 0.001086107, 0.001810178, 0.000724071, 0.001086107, 0.0009050888, 0.001448142, 0.001448142, 0.004344426, 0.003077302, 0.002715266, 0.001991195, 0.003620355, 0.003439337, 0.00325832, 0.003439337, 0.003620355, 0.001448142, 0.001991195, 0.001086107, 0.0005430533, 0.002534249, 0.003982391, 0.002534249, 0.001991195, 0.002353231, 0.003620355, 0.003982391, 0.0001810177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.0001810177, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.0001810177, 0, 0, 0, 0, 5.26472, 5.25929, 5.250601, 5.266892, 5.240102, 5.222724, 5.19702, 5.245894, 5.258204, 5.287167, 8.417326, 8.394156, 8.317404, 8.231602, 8.194312, 8.217844, 8.275408, 8.328988, 8.45715, 8.496249, 35.64529, 35.51062, 36.02905, 35.82812, 36.04353, 35.86215, 35.77707, 35.79952, 35.04902, 35.18008, 47.61057, 47.78615, 47.67139, 47.55047, 47.52187, 47.41507, 47.6522, 47.44439, 47.44475, 47.60079, 55.7274, 55.60974, 55.51995, 55.40338, 54.88531, 54.93092, 54.92332, 54.93129, 55.09818, 54.93925, 68.03262, 67.96565, 67.78463, 67.31471, 67.4273, 67.03486, 67.39617, 67.22131, 67.24013, 67.22094, 90.02158, 90.4314, 90.27464, 89.96329, 90.08675, 90.93934, 91.28219, 90.98206, 91.1685, 92.49863, 67.83858, 67.59782, 67.21153, 67.22818, 66.68259, 66.56566, 66.80605, 66.6902, 66.86144, 66.77818, 98.71839, 98.83642, 98.5667, 98.46171, 98.45158, 98.21697, 98.22132, 98.52543, 98.13696, 98.52398, 71.07843, 70.98322, 70.72255, 70.76527, 70.57701, 70.53284, 70.46188, 70.45356, 70.41554, 70.6114, 71.92849, 71.71236, 71.59397, 71.56573, 71.57225, 71.52409, 71.33186, 71.40354, 71.43323, 71.33331, 2.041518, 2.087135, 2.104874, 2.048759, 2.045139, 2.056362, 2.059982, 2.075187, 2.142164, 2.177282, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.09630144, 0.09774959, 0.0937672, 0.09014684, 0.0937672, 0.06987286, 0.08725056, 0.08182003, 0.08725056, 0.1234541, 0.000724071, 0.000724071, 0, 0, 0.0003620355, 0, 0.0003620355, 0.000724071, 0, 0.001448142, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0.002172213, 0.003982391, 0.004706461, 0.005068497, 0.003620355, 0.006154604, 0.004706461, 0.003982391, 0.006878674, 0.004706461, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  Bit QA Flags Last Value=819336
  Bit QA Flags Change=8200
  Granule Average QA Values=285.0182, 284.9929, 284.9943, 284.9859, 284.9838, 284.9787, 285.0185, 285.0146, 284.9998, 284.9824, 284.9743, 284.9702, 267.8564, 268.0114, 82.97041, 82.84912, 273.1707, 273.1338, 273.6953, 272.4779, 273.2531, 272.4182, 271.6044, 267.2137, 267.4213, 267.4177, 267.5054, 82.61301, 82.55436, 125.5092, 125.3761, 173.8001, 0.01046193, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  Electronics Redundancy Vector=44756138, 2084
  Electronics Configuration Change=0, 0
  Reflective LUT Serial Number and Date of Last Change=R084 2006:05:02:15:08
  Emissive LUT Serial Number and Date of Last Change=E083 2006:05:02:15:08
  QA LUT Serial Number and Date of Last Change=Q083 2006:05:02:15:08
  Focal Plane Set Point State=1
  Doors and Screens Configuration=192
  Reflective Bands With Bad Data=0, 1, 1, 1, 1, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 1, 1
  Emissive Bands With Bad Data=1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  Noise in Black Body Thermistors=1, 5, 9, 1, 3, 7, 9, 3, 6, 4, 11, 5
  Noise in Average BB Temperature=15
  Noise in LWIR FPA Temperature=15
  Noise in MWIR FPA Temperature=10
  Noise in Scan Mirror Thermistor #1=0
  Noise in Scan Mirror Thermistor #2=0
  Noise in Scan Mirror Thermistor Average=0
  Noise in Instrument Temperature=0
  Noise in Cavity Temperature=0
  Noise in Temperature of NIR FPA=0
  Noise in Temperature of Vis FPA=0
  Dead Detector List=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 1, 0, 1, 1, 1, 1, 0, 0, 1, 0, 1, 1, 1, 1, 1, 0, 1, 1, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0
  Noisy Detector List=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0
  Detector Quality Flag=0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 66, 64, 66, 64, 66, 66, 66, 66, 64, 64, 66, 64, 66, 66, 66, 66, 66, 65, 66, 66, 66, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 4, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 64, 64, 64, 64, 64, 64, 64, 64, 64, 64, 0, 0, 1, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 2, 0, 0, 0, 0, 0
  Earth-Sun Distance=1.011329
  Solar Irradiance on RSB Detectors over pi=511.5847, 511.5847, 511.5847, 511.5847, 511.5847, 511.5847, 511.5847, 511.5681, 511.6439, 511.7642, 511.8329, 511.8869, 511.9466, 511.989, 512.0393, 512.0604, 512.0804, 512.0942, 512.0903, 512.0883, 512.093, 512.0934, 512.0903, 512.0821, 512.062, 512.0376, 511.998, 511.9641, 511.9197, 511.849, 511.802, 511.802, 511.802, 511.802, 511.802, 511.802, 511.802, 511.802, 511.802, 511.802, 315.487, 315.487, 315.487, 315.487, 315.487, 315.487, 315.487, 315.4888, 315.4988, 315.5071, 315.5167, 315.5217, 315.5312, 315.5349, 315.5373, 315.5381, 315.5366, 315.5335, 315.5343, 315.5335, 315.5268, 315.5221, 315.5186, 315.5095, 315.505, 315.4981, 315.4882, 315.4736, 315.4604, 315.4509, 315.4449, 315.4714, 315.5046, 315.5408, 315.5948, 315.7431, 315.8229, 315.8856, 315.8856, 315.8856, 664.7366, 664.7366, 664.7366, 664.7366, 664.7001, 664.7471, 664.7432, 664.7266, 664.7188, 664.7175, 664.7213, 664.7332, 664.6851, 664.7102, 664.6629, 664.6442, 664.6538, 664.5352, 664.5352, 664.5352, 593.7072, 593.7072, 593.7072, 593.7072, 593.7002, 593.7049, 593.7009, 593.7031, 593.705, 593.7073, 593.7085, 593.7102, 593.7186, 593.7206, 593.7256, 593.7644, 593.7889, 593.8388, 593.8388, 593.8388, 151.1796, 151.1796, 151.1796, 151.1796, 151.1796, 151.1736, 151.1773, 151.1852, 151.1772, 151.1772, 151.1794, 151.1822, 151.1736, 151.1762, 151.1933, 151.1835, 151.1895, 151.1704, 151.1704, 151.1704, 76.58249, 76.58249, 76.58249, 76.58249, 76.58288, 76.58443, 76.58517, 76.58396, 76.58341, 76.59081, 76.5913, 76.58757, 76.58487, 76.63879, 76.59094, 76.59262, 76.58382, 76.5772, 76.5772, 76.5772, 28.77769, 28.77769, 28.77769, 28.77769, 28.77304, 28.77208, 28.77557, 28.77727, 28.77688, 28.77847, 28.77579, 28.77209, 28.77242, 28.77489, 28.77381, 28.77135, 28.7709, 28.77033, 28.77033, 28.77033, 556.0842, 556.0842, 556.0053, 556.1355, 556.2669, 556.4036, 556.5035, 556.7288, 556.5127, 556.51, 606.8428, 606.8428, 606.8634, 606.7712, 606.714, 606.7194, 606.7739, 606.7804, 606.5257, 606.7693, 629.313, 629.313, 629.313, 629.4122, 629.4171, 629.3915, 629.2726, 629.1608, 629.4336, 629.3894, 600.215, 600.215, 600.215, 600.1813, 600.1444, 600.1643, 600.2406, 600.2057, 599.6879, 599.6879, 602.4011, 602.4011, 602.4814, 602.4875, 602.497, 602.5059, 602.5154, 602.5306, 602.5897, 602.696, 492.4797, 492.4797, 492.5938, 492.6044, 492.6185, 492.6247, 492.6229, 492.6167, 492.582, 492.5184, 492.4797, 492.4797, 492.5938, 492.6044, 492.6185, 492.6247, 492.6229, 492.6167, 492.582, 492.5184, 479.4278, 479.4278, 479.4126, 479.4116, 479.4093, 479.4072, 479.4096, 479.4182, 479.4037, 479.3895, 479.4278, 479.4278, 479.4126, 479.4116, 479.4093, 479.4072, 479.4096, 479.4182, 479.4037, 479.3895, 412.0707, 412.0707, 412.1205, 412.1488, 412.1434, 412.1468, 412.1477, 412.0982, 412.0902, 412.0751, 309.7169, 309.7169, 309.7085, 309.7431, 309.7635, 309.7625, 309.7625, 309.7609, 309.8164, 310.0857, 297.4603, 297.4603, 297.462, 297.4626, 297.4647, 297.4636, 297.4626, 297.4617, 297.46, 297.46, 277.6909, 277.6909, 277.6905, 277.691, 277.6906, 277.6904, 277.6903, 277.6896, 277.6893, 277.6893, 277.9197, 277.9197, 277.9197, 277.9191, 277.9202, 277.9189, 277.9188, 277.9177, 277.9178, 277.9178, 116.2086, 116.2086, 116.2058, 116.2001, 116.1993, 116.2024, 116.2058, 116.2076, 116.2047, 116.2047
Subdatasets:
  SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB
  SUBDATASET_1_DESC=[15x2040x1354] EV_1KM_RefSB MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_1KM_RefSB_Uncert_Indexes
  SUBDATASET_2_DESC=[15x2040x1354] EV_1KM_RefSB_Uncert_Indexes MODIS_SWATH_Type_L1B (8-bit unsigned integer)
  SUBDATASET_3_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_1KM_Emissive
  SUBDATASET_3_DESC=[16x2040x1354] EV_1KM_Emissive MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_4_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_1KM_Emissive_Uncert_Indexes
  SUBDATASET_4_DESC=[16x2040x1354] EV_1KM_Emissive_Uncert_Indexes MODIS_SWATH_Type_L1B (8-bit unsigned integer)
  SUBDATASET_5_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_250_Aggr1km_RefSB
  SUBDATASET_5_DESC=[2x2040x1354] EV_250_Aggr1km_RefSB MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_6_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_250_Aggr1km_RefSB_Uncert_Indexes
  SUBDATASET_6_DESC=[2x2040x1354] EV_250_Aggr1km_RefSB_Uncert_Indexes MODIS_SWATH_Type_L1B (8-bit unsigned integer)
  SUBDATASET_7_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_250_Aggr1km_RefSB_Samples_Used
  SUBDATASET_7_DESC=[2x2040x1354] EV_250_Aggr1km_RefSB_Samples_Used MODIS_SWATH_Type_L1B (8-bit integer)
  SUBDATASET_8_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_500_Aggr1km_RefSB
  SUBDATASET_8_DESC=[5x2040x1354] EV_500_Aggr1km_RefSB MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_9_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_500_Aggr1km_RefSB_Uncert_Indexes
  SUBDATASET_9_DESC=[5x2040x1354] EV_500_Aggr1km_RefSB_Uncert_Indexes MODIS_SWATH_Type_L1B (8-bit unsigned integer)
  SUBDATASET_10_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_500_Aggr1km_RefSB_Samples_Used
  SUBDATASET_10_DESC=[5x2040x1354] EV_500_Aggr1km_RefSB_Samples_Used MODIS_SWATH_Type_L1B (8-bit integer)
  SUBDATASET_11_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:Height
  SUBDATASET_11_DESC=[408x271] Height MODIS_SWATH_Type_L1B (16-bit integer)
  SUBDATASET_12_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:SensorZenith
  SUBDATASET_12_DESC=[408x271] SensorZenith MODIS_SWATH_Type_L1B (16-bit integer)
  SUBDATASET_13_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:SensorAzimuth
  SUBDATASET_13_DESC=[408x271] SensorAzimuth MODIS_SWATH_Type_L1B (16-bit integer)
  SUBDATASET_14_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:Range
  SUBDATASET_14_DESC=[408x271] Range MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_15_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:SolarZenith
  SUBDATASET_15_DESC=[408x271] SolarZenith MODIS_SWATH_Type_L1B (16-bit integer)
  SUBDATASET_16_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:SolarAzimuth
  SUBDATASET_16_DESC=[408x271] SolarAzimuth MODIS_SWATH_Type_L1B (16-bit integer)
  SUBDATASET_17_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:gflags
  SUBDATASET_17_DESC=[408x271] gflags MODIS_SWATH_Type_L1B (8-bit unsigned integer)
  SUBDATASET_18_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_Band26
  SUBDATASET_18_DESC=[2040x1354] EV_Band26 MODIS_SWATH_Type_L1B (16-bit unsigned integer)
  SUBDATASET_19_NAME=HDF4_EOS:EOS_SWATH:"TDS_MYD021KM_04_delay.hdf":MODIS_SWATH_Type_L1B:EV_Band26_Uncert_Indexes
  SUBDATASET_19_DESC=[2040x1354] EV_Band26_Uncert_Indexes MODIS_SWATH_Type_L1B (8-bit unsigned integer)
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  512.0)
Upper Right (  512.0,    0.0)
Lower Right (  512.0,  512.0)
Center      (  256.0,  256.0)
