[gdal-dev] Appending a column on shapefile import to postgis via ogr2ogr
Fri May 23 15:00:37 EDT 2008
On 5/23/08, Aaron Racicot <aaronr at z-pulley.com> wrote:
>  Is something like that possible?
>  Basically in the end I would like something like:
>  ogr2ogr -update -append -f PostgreSQL PG:'host=localhost user=racicot
>  dbname=xxx' -sql "select 'aaronr' as author, * from test" test.shp -nln
>  user_shapes
>  My hope was that I could add the author field to the -sql statement and have
>  it populate the 'author' column in my postgis table.  If something like this
>  from the command line would work then I could just swap in an arbitrary
>  username for 'aaronr' in the above example on the data import via my script
>  and have a unique way to keep track of the data once it is imported.
Aaron,
I'm afraid this isn't possible because the SQL statement is being
evaluated by the OGR SQL engine in this case, and the OGR SQL
engine is quite limited.  It lacks, for instance, the ability add
columns in the select from fixed values.
Sorry!
The OGR SQL document should give some ideas of the limitations
of the OGR SQL engine.
Best regards,
