[gdal-dev] GDALINFO fails with large .tif raster
Even Rouault even.rouault at mines-paris.org
Sat May 24 04:09:16 EDT 2008
I've downloaded your TIFF image and tried it with different GDAL versions :
GDAL SVN with internal libtiff, GDAL 1.5 branch with my system libtiff
(3.8.2-7ubuntu2), and GDAL 1.4.1 (Ubuntu package libgdal1-1.4.0,
1.4.1-6build1) with system libtiff, and all of them can gdalinfo successfully
on it.
Have you tried to run 'tiffdump' on your TIFF image ?
Best regards,
Even
Le Friday 23 May 2008 01:04:09 Marius Jigmond, vous avez écrit :
> I am posting this at Jachym Cepicky's suggestion as I had originally
> posted it on the QGIS forum. I cannot open large (2.7 GB) .tif rasters
> on a Ubuntu Hardy distribution. I have tried gdal 1.4.4 from Ubuntu,
> 1.5.1 from Jachym's repo, and the version distributed with the 2.0.6
> version of FWTools. Here's some output:
> marius at snowcrave:~$ gdalinfo GISdata/Romania/LandsatMosaics/bands123.tif
> ERROR 4: `GISdata/Romania/LandsatMosaics/bands123.tif' not recognised as
> a supported file format.
> gdalinfo failed - unable to open
> 'GISdata/Romania/LandsatMosaics/bands123.tif'.
> I know the raster file is fine because I can read it on a Ubuntu Gutsy
> box with gdal 1.4.2. Here's the output from the Gutsy box:
> marius at bigfoot:~$ gdalinfo /media/hdb7/bands123.tif
> Driver: GTiff/GeoTIFF
> Size is 31865, 30113
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 35N",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.2572235629972,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",27],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","32635"]]
> Origin = (-126751.937963147182018,5526477.750000000000000)
> Pixel Size = (28.500000000000000,-28.500000000000000)
> Metadata:
>   AREA_OR_POINT=Area
>   TIFFTAG_SOFTWARE=IMAGINE TIFF Support
> Copyright 1991 - 1999 by ERDAS, Inc. All Rights Reserved
> @(#)$RCSfile: etif.c $ $Revision: 1.10.1.9.1.9.2.11 $ $Date: 2004/09/15
> 18:42:01EDT $
>   TIFFTAG_XRESOLUTION=1
>   TIFFTAG_YRESOLUTION=1
>   TIFFTAG_RESOLUTIONUNIT=1 (unitless)
> Corner Coordinates:
> Upper Left  ( -126751.938, 5526477.750) ( 18d19'38.37"E, 49d33'53.29"N)
> Lower Left  ( -126751.938, 4668257.250) ( 19d26'39.47"E, 41d55'1.31"N)
> Upper Right (  781400.562, 5526477.750) ( 30d54'46.05"E, 49d49'28.61"N)
> Lower Right (  781400.562, 4668257.250) ( 30d24'13.74"E, 42d 6'57.36"N)
> Center      (  327324.312, 5097367.500) ( 24d46'10.68"E, 46d 0'29.21"N)
> Band 1 Block=31865x1 Type=Byte, ColorInterp=Gray
> Band 2 Block=31865x1 Type=Byte, ColorInterp=Undefined
> Band 3 Block=31865x1 Type=Byte, ColorInterp=Undefined
> On the Hardy box I have encrypted ext3 partitions, while on the Gutsy
> they are unencrypted ext3. I placed the raster on an unencrypted
> partition, but that didn't help. Gdalinfo works with smaller (900 MB)
> .tif rasters on the Hardy box. I look forward to any suggestions you
> might have. The QGIS post can be accesed here:
> http://forum.qgis.org/viewtopic.php?f=2&t=783. Thanks.
> Marius
> _________________________________________________________________
> Keep your kids safer online with Windows Live Family Safety.
> http://www.windowslive.com/family_safety/overview.html?ocid=TXT_TAGLM_WL_Re
>fresh_family_safety_052008
