[Gdal-dev] gdal_grid: taking a value from feature attribute
    Andrey Kiselev
    dron at ak4719.spb.edu
    Mon May 26 06:58:55 EDT 2008
On Sun, May 25, 2008 at 12:49:38AM -0700, Fodder wrote:
> It seems like a good little tool, are there any plans to put in
> splines or kriging?
I would like to see the wide range of methods to be implemented, but I
have now short term plans to do it myself. But any contributions are
welcome. I tried to make gridding interface simple enough and suitable
for further additions:
 http://trac.osgeo.org/gdal/browser/trunk/gdal/alg/gdalgrid.cpp
> Is it mostly for points or does it work with polylines & polgons too?
It will use the points only, but can be easily extended to handle
polygons and polylines too.  It will collect a list of nodes and use it
in the same way as list of points, so no extra intelligence here. I can
add an option to enable such a behavior.
Best regards,
Andrey
Andrey V. Kiselev
ICQ# 26871517
