[gdal-dev] GDAL Warp working intermittetently
Christiaan Janssen cjanssen at iavo-rs.com
Mon May 26 15:39:11 EDT 2008
I apologize if this has already been answered previously, but I am trying to
use the GDALWarp functionality and the process appears to be working only
intermittently.  I am using the 1.5.0 build of GDAL.  The first time I try
to use the warp functions when a project is opened, the results appear to be
correct.  If I subsequently run the warp again (using the same data) I have
been getting erroneous results.  For the image warping
(oOperation.ChunkAndWarpImage) the output is an all black image.  For the
point warping (GDALTPSTransform) the result is extremely high values.  In
both cases, if I set a breakpoint in the debugger post-operation, and then
set the active statement to the beginning of the setup function, the warping
results are suddenly correct.
Does anyone have experience with this type of issue with the GDALWarp
library?
The code that shows these issues is below..
Warp Image:
psWarpOptions->pTransformerArg = GDALCreateTPSTransformer(tieIn->Count,
tiePoints, 0);
psWarpOptions->pfnTransformer = GDALTPSTransform;
psWarpOptions->eResampleAlg = GRA_Bilinear;
GDALWarpOperation oOperation;
oOperation.Initialize( psWarpOptions );
CPLErr err = oOperation.ChunkAndWarpImage(0, 0, ihOut->ImageWidth,
ihOut->ImageHeight);
Warp Points:
GDALTransformerFunc* gFunc =
(GDALTransformerFunc*)GDALCreateTPSTransformer(tieIn->Count, tiePoints, 0);
GDALTPSTransform(gFunc, 0, pWarp->Count, dX, dY, dZ, iSuc);
Thanks for your help!
Christiaan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080526/8150335f/attachment.html
