[Gdal-dev] building gdal with local xerces/proj4
VJorg jorg.verstraete at incgeo.be
Tue May 27 09:46:30 EDT 2008
I managed to get what I want, by adding
export LDFLAGS="-Wl,--rpath -Wl,."
and then put all the relevant .so file in the appropriate folder.
All dependancies from these .so files are now correct, pointing to the ones
I want AND using a relative path.
Jörg
View this message in context: http://www.nabble.com/building-gdal-with-local-xerces-proj4-tp17486002p17490814.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
