[gdal-dev] Compiling GDAL-1.5.1 on Linux
Lucena, Ivan ivan.lucena at pmldnet.com
Tue May 27 12:02:26 EDT 2008
Frank,
I didn't mentioned before but I also tried --disable-curl --disable-wms --disable-wcs. In the meantime I decided to try the 151RC1
But the "--without-curl" worked fine. It shows on the final ./confure report that the OGC services are disabled.
The version og cURL that I have here is:
$ curl-config --version
libcurl 7.10.6
I can add a ticked for that, sure.
Continuing the build the process I am facing another error:
kml.h:41:2: #error "Old version of expat, please upgrade to expat 2.x"
I will try --without-kml ?
Thanks,
Ivan
>  -------Original Message-------
>  From: Frank Warmerdam <warmerdam at pobox.com>
>  Subject: Re: [gdal-dev] Compiling GDAL-1.5.1 on Linux
>  Sent: May 27 '08 15:37
>  Lucena, Ivan wrote:
>  > Hi Folks,
>  > I am having some problems compiling on a Linux machine. I would like to disable all the driver that I am having problem with but I am not sure how to do that. I just need some basic rasters drivers like GTIFF and JPG for a temporary use and I am not familiar with all the setting on ./configure.
>  > Here is the error:
>  > gdalhttp.cpp: In function `CPLErr CPLHTTPFetchMulti(CPLHTTPRequest*, int, const char* const*)':
>  > gdalhttp.cpp:209: `CURLINFO_RESPONSE_CODE' undeclared (first use this function)
>  > gdalhttp.cpp:209: (Each undeclared identifier is reported only once for each function it appears in.)
>  > make[2]: *** [../o/gdalhttp.o] Error 1
>  > make[2]: Leaving directory `/home/lucena/gdal-1.5.1/frmts/wms
>  > make[1]: *** [wms-install-obj] Error 2
>  > make[1]: Leaving directory `/home/lucena/gdal-1.5.1/frmts'
>  > make: *** [frmts-target] Error 2
>  > I tried that:
>  > ./confugure --disable-wms
>  > but it doesn't help.
>  > Any hint is welcome.
>  Ivan,
>  Try --without-curl
>  The error is (I believe) due to use of relatively modern curl
>  features by the gdalhttp module in the wms driver.
>  Actually, what version of curl are you using?  (try curl-config --version)
>  If you wouldn't mind, I'd appreciate your filing a ticket with the error,
>  and the curl version you are using.  Then I could look into some sort of
>  fallback or better error in the WMS driver.
>  Best regards,
>  I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>  light and sound - activate the windows | http://pobox.com/~warmerdam
>  and watch the world go round - Rush    | President OSGeo, http://osgeo.org
