[gdal-dev] Re: Cannot build on linux
zhao peisheng
zhaops at hotmail.com
Thu May 29 21:49:21 EDT 2008
I recomplie the HDF without NetCDF support under my own directory. In configuration of GDAL, I specify to use these recompiled HDF and NetCDF. But the error still shows using the HDF and NetCDF under system directory, not the one under my own directory.
> From: ivan.lucenao at pmldnet.com
> To: zhaops at hotmail.com; gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Re: Cannot build on linux
> Date: Fri, 30 May 2008 00:06:14 +0000
> I am not an specialist on that topic but I believe that you need to recompile the HDF libraries wihout NetCDF support in order to use the NetCDF driver. Maybe that is what "multiple definition" is about.
> > -------Original Message-------
> > From: peisheng <zhaops at hotmail.com>
> > Subject: [gdal-dev] Re: Cannot build on linux
> > Sent: May 29 '08 21:50
> > I also can not compiling GDAL.
> > I want to install all GDAL, NetCDF and HDF under my own directory, then use
> > ./configure --without-ogdi
> > --with-netcdf=/tools/gdaac/TS2/www/maptest/pzhao/supportlibs
> > --with-proj=/usr/local
> > --with-hdf4=/tools/gdaac/TS2/www/maptest/pzhao/supportlibs
> > --with-hdf5=/tools/gdaac/TS2/www/maptest/pzhao/supportlibs --without-python
> > --without-perl --prefix=/tools/gdaac/TS2/www/maptest/pzhao/supportlibs
> > --with-libtiff=internal
> > But I got some errors:
> > /usr/local/lib/libnetcdf.a(attr.o)(.text+0x366): In function `NC_findattr':
> > : multiple definition of `NC_findattr'
> > /usr/local//lib/libmfhdf.a(attr.o)(.text+0x124): first defined here
> > /usr/bin/ld: Warning: size of symbol `NC_findattr' changed from 121 in
> > /usr/local//lib/libmfhdf.a(attr.o) to 133 in /usr/local/lib/libnetcdf.a(attr.o)
> > /usr/local/lib/libnetcdf.a(putget.o)(.text+0x0): In function `nctypelen':
> > : multiple definition of `nctypelen'
> > /usr/local//lib/libmfhdf.a(array.o)(.text+0xec): first defined here
> > /usr/bin/ld: Warning: size of symbol `nctypelen' changed from 103 in
> > /usr/local//lib/libmfhdf.a(array.o) to 53 in /usr/local/lib/libnetcdf.a(putget.o)
> > /usr/local/lib/libnetcdf.a(nc.o)(.text+0x67): In function `NC_check_id':
> > : multiple definition of `NC_check_id'
> > /usr/local//lib/libmfhdf.a(file.o)(.text+0x0): first defined here
> > /usr/bin/ld: Warning: size of symbol `NC_check_id' changed from 76 in
> > /usr/local//lib/libmfhdf.a(file.o) to 53 in /usr/local/lib/libnetcdf.a(nc.o)
> > /usr/local/lib/libnetcdf.a(var.o)(.text+0x47f): In function `NC_var_shape':
> > : multiple definition of `NC_var_shape'
> > /usr/local//lib/libmfhdf.a(var.o)(.text+0x1b0): first defined here
> > /usr/bin/ld: Warning: size of symbol `NC_var_shape' changed from 563 in
> > /usr/local//lib/libmfhdf.a(var.o) to 292 in /usr/local/lib/libnetcdf.a(var.o)
> > collect2: ld returned 1 exit status
> > make[1]: *** [libgdal.la] Error 1
> > make[1]: Leaving directory `/tools/gdaac/TS2/www/maptest/pzhao/gdal/gdal-1.5.1'
> > make: *** [check-lib] Error 2
> > It seems it is looking for netcdf and hdf in system directory, although I
> > specify to use netcdf and hdf located at my own directory
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
_________________________________________________________________
Change the world with e-mail. Join the i’m Initiative from Microsoft.
http://im.live.com/Messenger/IM/Join/Default.aspx?source=EML_WL_ChangeWorld
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20080530/98c4a7ac/attachment.html
