[gdal-dev] Motion: Adopt GDAL/OGR 1.5.2 RC3 as 1.5.2
William Kyngesburye woklist at kyngchaos.com
Sat May 31 14:01:06 EDT 2008
OSX 10.5 Leopard build mostly OK.  One new failure in the autotests:
   TEST: isis_1 ...
old =  PROJCS["Equirectangular Mars",
     GEOGCS["GCS_Mars",
         DATUM["D_Mars",
             SPHEROID["Mars_localRadius",3394813857.975946,0]],
         PRIMEM["Reference_Meridian",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Equirectangular"],
     PARAMETER["latitude_of_origin",-15.14700031280518],
     PARAMETER["central_meridian",184.4129943847656],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",0]]
new =  PROJCS["Equirectangular Mars",
     GEOGCS["GCS_Mars",
         DATUM["D_Mars",
             SPHEROID["Mars_localRadius",3394813.857975945,0]],
fail
     Projections differ
   TEST: isis_2 ...
fail
similar failure - spheroid off by magnitude of 1000
The WCS/WMS tests also had connection failures - refused/system
overload.
I'm still using HDF4.2r2 and HDF5 1.6.x, so I don't have the problems
others are having with those.
I've updated to the latest Xcode 3.1 beta on Leopard (iPhone SDK
beta), and it looks like the one optimization problem with the geotiff
driver is gone :)
But I still have the odd makefile issue where it builds the object
files as *.lo + .libs/*.o, but the target deps are *.o, so everything
gets recompiled when I make install after make, with the side effect
that the apps can't find the *.o to link into their binaries.  I have
to remove 'default' from the install target deps so it doesn't
recompile everything, and change all the app targets to link the *.lo
objects.
On May 29, 2008, at 3:36 PM, Frank Warmerdam wrote:
> Folks,
> I have a new release candidate up that includes the CPLAtof() fixes
> (#2036 related) as well as some GeoJSON improvements.
>  http://download.osgeo.org/gdal/gdal-1.5.2RC3.tar.gz
>  http://download.osgeo.org/gdal/gdal152RC3.zip
> Motion: GDAL 1.5.2 RC2 is adopted as the official GDAL 1.5.2 release.
> Please vote after testing within the next two days, and we can issue
> the
> official release on Tuesday (I'm out Monday).
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Mon Dieu! but they are all alike.  Cheating, murdering, lying,
fighting, and all for things that the beasts of the jungle would not
deign to possess - money to purchase the effeminate pleasures of
weaklings.  And yet withal bound down by silly customs that make them
slaves to their unhappy lot while firm in the belief that they be the
lords of creation enjoying the only real pleasures of existence....
- the wisdom of Tarzan
