[gdal-dev] MSYS buildslave
Even Rouault even.rouault at mines-paris.org
Sat Nov 1 12:45:50 EDT 2008
Ari,
fopr the crash in MEMRasterBand::IReadBlock(), I would suspect that
CPLScanPointer doesn't do its job rightly when compiled in MSYS environment.
The function looks currently like :
/*      On MSVC we have to scanf pointer values without the 0x          */
/*      prefix.                                                         */
    if( EQUALN(szTemp,"0x",2) )
        pResult = NULL;
#if defined(WIN32) && defined(_MSC_VER)
        sscanf( szTemp+2, "%p", &pResult );
#else
        sscanf( szTemp, "%p", &pResult );
#endif
I'd guess we probably don't need the defined(_MSC_VER) test
Le Saturday 01 November 2008 17:29:17 Ari Jolma, vous avez écrit :
> The wrappers seemed to build with Python 2.4 without other changes than
> uncommenting libraries = gdal in setup.cfg. setup.py seems to set gdal_i
> by default in windows.
> The autotest dumps core in usgsdem.py test 4 (the culprit is memcpy in
> MEMRasterBand::IReadBlock), but I'm not sure if I have the most recent
> gdal right now.
> These are not yet in the buildslave, which currently is failing because
> I have something running there which keeps the swig/python directory
> undeleteable - damn windows!
> Ari
> Christopher Barker kirjoitti:
> > Andrey Kiselev wrote:
> >> Otherwise of that bug Python stuff should be perfectly compilable and
> >> usable with the official binary Python distribution.
> > At least with python2.5 I'm not sure about 2.6, but earlier pythons
> > required some patching to work with MingGW binaries.
> > -Chris
