[gdal-dev] GDAL reference counting is thread unsafe
Martin Chapman mchapman at fortifieddatacom.com
Sat Nov 1 22:53:08 EDT 2008
If anyone is interested the following code has been used safely on Windows
and Linux for thread safe reference counting.  You can paste it into a
header file if you want, or use it as a guide.  It uses pthreads on Linux
and the Win32 thread functions on Windows with InterlockedIncrement() and
InterlockedDecrement().
Best regards,
Martin
#ifndef Increment_h
#define Increment_h
#define _WINDOWS_
#ifndef _WINDOWS_
#include <pthread.h>
#include <bits/pthreadtypes.h>
#endif
class CIncrement
public:
	#ifdef _WINDOWS_
	CRITICAL_SECTION m_CS;
	#endif
CIncrement()
	#ifndef _WINDOWS_
	pthread_mutex_init(&m_Mutex, NULL);
	#endif
	#ifdef _WINDOWS_
	InitializeCriticalSection(&m_CS);
	#endif
	#ifdef _WINDOWS_
	EnterCriticalSection(&m_CS);
	#endif
	m_nVal = 0;
	#ifdef _WINDOWS_
	LeaveCriticalSection(&m_CS);
	#endif
~CIncrement()
	#ifndef _WINDOWS_
	pthread_mutex_destroy (&m_Mutex);
	#endif
	#ifdef _WINDOWS_
	DeleteCriticalSection(&m_CS);
	#endif
CIncrement& operator=(const CIncrement& thread)
    if (this == &thread)
        return *this;
	#ifndef _WINDOWS_
    pthread_mutex_lock(&m_Mutex);
    #endif
	#ifdef _WINDOWS_
	#endif
    m_nVal = thread.m_nVal;
	#ifdef _WINDOWS_
	#endif
    #ifndef _WINDOWS_
    pthread_mutex_unlock(&m_Mutex);
    #endif
    return *this;
int operator++(int nVal)
    return Add(1, true);
int operator++()
    return Add(1, false);
int operator--(int nVal)
    return Add(-1, true);
int operator--()
    return Add(-1, false);
bool operator==(const int nVal)
    #ifndef _WINDOWS_
    #endif
	#ifdef _WINDOWS_
	#endif
    bool bReturn = (m_nVal == nVal);
	#ifdef _WINDOWS_
	#endif
    #ifndef _WINDOWS_
    #endif
    return bReturn;
int Add(int nNum, bool bReturnNew)
    int rtn = 0;
    #ifdef _WINDOWS_
    return nNum > 0 ? InterlockedIncrement((volatile LONG*) &m_nVal)
					: InterlockedDecrement((volatile
LONG*) &m_nVal);
    #else
    int oVal = m_nVal;
    m_nVal += nNum;
    rtn = bReturnNew ? m_nVal : oVal;
    #endif
    return rtn;
protected:
	int m_nVal;
	#ifdef _WINDOWS_
	void* m_Mutex;
	#else
	pthread_mutex_t m_Mutex;
	#endif
#endif
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Tamas Szekeres
Sent: Saturday, November 01, 2008 5:40 PM
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] GDAL reference counting is thread unsafe
Folks,
I've found the following issue with the current refcounting
implementation in GDAL:
http://trac.osgeo.org/gdal/ticket/2648
Do you have idea whether we could handle this problem possibly for the
next release?
Best regards,
Tamas
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
