[gdal-dev] gdal_merge
Matt Wilkie matt.wilkie at gov.yk.ca
Tue Nov 4 15:02:15 EST 2008
> By the way, to get the order of precidence you want you should also
> reverse the order of the input images so that image1.tif is last
> (overlayed to top of everything else).
Thanks for clarifying this Frank.
Is there way to do the same with gdalwarp? I ask because I sometimes
need to stack images rather than blend them, but also want to use
bilinear or cubic resampling.
cheers,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
http://environmentyukon.gov.yk.ca/geomatics/
