[gdal-dev] JPEG2000 issues
Stephen Woodbridge woodbri at swoodbridge.com
Fri Nov 7 12:32:21 EST 2008
Stephen Woodbridge wrote:
> Hi Frank, et al,
> I'm working with GDAL 1.5.3, released 2008/09/09 built with libjasper so
> I can process some DOQQ composites and chop them into smaller tiles.
> Below is a typical image but I get a bunch of errors in gdalinfo. The
> system has like 6 GB of memory and only about 1.5GB of swap. The
> compressed image is huge at 538MB. I tried 3-4 images in the directory
> and got the same report on all of them.
> Any thoughts on this?
> Is this a real problem, ie. I will not be able to access these images.
> Other options solutions?
> We also have JP2MrSID support, is there a way to force it to use this
> driver instead of the JPEG2000 driver and see if that works any better?
> Thanks,
>   -Steve
> $ ls -lh /var/data/raw_data/indiana/ortho_1-1_1m_j_in175_2008_1.jp2
> -rw-rw-r--  1 dallen users 563M Oct 20 16:17
> $ gdalinfo /var/data/raw_data/indiana/ortho_1-1_1m_j_in175_2008_1.jp2
> Driver: JPEG2000/JPEG-2000 part 1 (ISO/IEC 15444-1)
> Files: /var/data/raw_data/indiana/ortho_1-1_1m_j_in175_2008_1.jp2
> Size is 44462, 49524
> Coordinate System is:
> PROJCS["NAD83 / UTM zone 16N",
>     GEOGCS["NAD83",
>         DATUM["North_American_Datum_1983",
>             SPHEROID["GRS 1980",6378137,298.2572221010042,
>                 AUTHORITY["EPSG","7019"]],
>             AUTHORITY["EPSG","6269"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4269"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",-87],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","26916"]]
> Origin = (559388.000000000000000,4296871.000000000000000)
> Pixel Size = (1.000000000000000,-1.000000000000000)
> Corner Coordinates:
> Upper Left  (  559388.000, 4296871.000) ( 86d18'57.27"W, 38d49'7.03"N)
> Lower Left  (  559388.000, 4247347.000) ( 86d19'12.47"W, 38d22'20.43"N)
> Upper Right (  603850.000, 4296871.000) ( 85d48'13.79"W, 38d48'52.19"N)
> Lower Right (  603850.000, 4247347.000) ( 85d48'40.36"W, 38d22'5.82"N)
> Center      (  581619.000, 4272109.000) ( 86d 3'45.98"W, 38d35'37.38"N)
> error: cannot decode code stream
> Band 1 Block=256x256 Type=Byte, ColorInterp=Undefined
> error: expecting signature box
>   Metadata:
>     LAYER_TYPE=athematic
> error: cannot get box
> <GDALRasterAttributeTable/>
> Band 2 Block=256x256 Type=Byte, ColorInterp=Undefined
>   Metadata:
> Band 3 Block=256x256 Type=Byte, ColorInterp=Undefined
>   Metadata:
> Band 4 Block=256x256 Type=Byte, ColorInterp=Undefined
>   Metadata:
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
I must be a Zen thing that I always find answers after a give up looking
and post to the list. So, to reply to myself, I was about to use the
JP2MrSID driver like the following and without any error. So, I'll try
to move forward using this more of access. I'm still interested in any
other thoughts you have on the above issues.
Thanks,
   -Steve
$ GDAL_SKIP=JPEG2000  gdalinfo
Driver: JP2MrSID/MrSID JPEG2000
     GEOGCS["NAD83",
             SPHEROID["GRS 1980",6378137,298.2572221010002,
     UNIT["metre",1,
Metadata:
   IMAGE__ENCODING_APPLICATION=GeoExpress 7.0.0.2052
   IMAGE__INPUT_FILE_SIZE=9095986793.000000
   IMAGE__INPUT_FORMAT=TIFF w/ World File
IMAGE__INPUT_NAME=O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\BECKS
MILL NE.tif,
MILL NW.tif,
MILL SE.tif,
MILL SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\BORDEN
NW.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\CAMPBELLSBURG
NE.tif,
SE.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\FREDERICKSBURG
NE.tif,
NW.tif,
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\HARDINSBURG
NE.tif,
SE.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\HENRYVILLE
NW.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\KOSSUTH
NE.tif,
NW.tif,
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\LITTLE
YORK NE.tif,
YORK NW.tif,
YORK SE.tif,
YORK SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\LIVONIA
NE.tif,
SE.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\MEDORA
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\PALMYRA
NE.tif,
NW.tif,
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\SALEM
NE.tif,
NW.tif,
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\SMEDLEY
NE.tif,
NW.tif,
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\SOUTH
BOSTON NE.tif,
BOSTON NW.tif,
BOSTON SE.tif,
BOSTON SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\TAMPICO
SE.tif,
SW.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\TUNNELTON
SE.tif,
O:\DMC_Output\13a\projects\5835-031_IN08\South_sheets_4edit\new_QQs\2-7_10-13_16-18\gtif\finals\Washington_IN_18175_49\VALLONIA
SE.tif,
SW.tif
   IMAGE__X_ROTATION=0.000000
   IMAGE__Y_ROTATION=0.000000
   GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
   GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
   GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
   GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
   GEOTIFF_NUM__2050__GeogGeodeticDatumGeoKey=6269
   GEOTIFF_CHAR__GeogGeodeticDatumGeoKey=Datum_North_American_Datum_1983
   GEOTIFF_NUM__2056__GeogEllipsoidGeoKey=7019
   GEOTIFF_CHAR__GeogEllipsoidGeoKey=Ellipse_GRS_1980
   GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=26916
   GEOTIFF_CHAR__ProjectedCSTypeGeoKey=PCS_NAD83_UTM_zone_16N
   GEOTIFF_NUM__3073__PCSCitationGeoKey=Universal Transverse Mercator;
North American 1983; GRS80
   GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9001
   GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Meter
   GEOTIFF_NUM__3080__ProjNatOriginLongGeoKey=-87.000000
   GEOTIFF_NUM__3081__ProjNatOriginLatGeoKey=0.000000
   GEOTIFF_NUM__3082__ProjFalseEastingGeoKey=500000.000000
   GEOTIFF_NUM__3083__ProjFalseNorthingGeoKey=0.000000
   GEOTIFF_NUM__3092__ProjScaleAtNatOriginGeoKey=0.999600
   IMAGE__BITS_PER_SAMPLE=8
   IMAGE__WIDTH=44462
   IMAGE__HEIGHT=49524
   IMAGE__COLOR_SCHEME=10
   IMAGE__DATA_TYPE=0
   IMAGE__DYNAMIC_RANGE_WINDOW=256.000000
   IMAGE__DYNAMIC_RANGE_LEVEL=127.500000
   IMAGE__NO_DATA_VALUE=0,0,0,0
   IMAGE__TRANSPARENT_DATA_VALUE=0,0,0,0
   IMAGE__XY_ORIGIN=559388.500000,4296870.500000
   IMAGE__X_RESOLUTION=1.000000
   IMAGE__Y_RESOLUTION=1.000000
   IMAGE__WKT=PROJCS["NAD83 / UTM zone
16N",GEOGCS["NAD83",DATUM["North_American_Datum_1983",SPHEROID["GRS
1980",6378137,298.2572221010002,AUTHORITY["EPSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Transverse_Mercator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-87],PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26916"]]
Corner Coordinates:
Band 1 Block=1024x128 Type=Byte, ColorInterp=Undefined
   Minimum=0.000, Maximum=194.000, Mean=83.074, StdDev=36.912
   Overviews: 22231x24762, 11116x12381, 5558x6191, 2779x3096, 1390x1548,
695x774, 348x387, 174x194, 87x97, 44x49, 22x25, 11x13, 6x7, 3x4
   Metadata:
Band 2 Block=1024x128 Type=Byte, ColorInterp=Undefined
   Minimum=0.000, Maximum=187.000, Mean=99.809, StdDev=40.469
   Metadata:
Band 3 Block=1024x128 Type=Byte, ColorInterp=Undefined
   Minimum=0.000, Maximum=166.000, Mean=102.323, StdDev=40.042
   Metadata:
Band 4 Block=1024x128 Type=Byte, ColorInterp=Undefined
   Minimum=0.000, Maximum=225.000, Mean=165.243, StdDev=63.705
   Metadata:
