[gdal-dev] KML problem
Christopher Condit condit at sdsc.edu
Fri Nov 7 16:02:17 EST 2008
Hi Bruce-
>I am using OGR to create both a shapefile and a KML file.  The data in the shapefile looks good and the >values in the KML are the same as in the shapefile but they are shifted up by 2 places.  There are 2 >extra attributes in the KML file (Name and Description). My "Longitude" value  appears in the >"Description" field.
>I tried to use CSLSetNameValue( ogrOptions, "DescriptionField", "None"); to eliminate the Description >field but it did not work.
I need to look into this. Can you either:
1) File a defect on trac and include the shapefile
2) Email me the shapefile and I'll create the defect
Thanks,
-Chris
Christopher Condit
San Diego Supercomputer Center
858-822-5483
condit at sdsc.edu
