[gdal-dev] Is GDAL reentrant
Mon Nov 10 08:53:52 EST 2008
Clay, Bruce wrote:
> I have a Microsoft application with multiple tabs / property pages.
>  Each tab is controlled by a separate class.  I have a separate instance
> of GDAL in each class.  I also had an instance in a popup that I used to
> connect to the database.  After the user logins and the popup window
> goes away it seems that I have to reregister the OGR drivers in the tabs
> as if the OGRCleanupAll in the destructor of the popup was being applied
> to the instances in the tabs as well.
> Is GDAL / OGR reentrant?  Can we have multiple instances that act
> independently?
Bruce,
GDAL/OGR is endeavors to achieve some forms of re-entrancy.  In particular
it should be possible to have distinct threads accessing distinct
GDALDataset objects in read-only mode for "well behaved" drivers.  This
is also generally true of OGRDataSource objects.
However, a call to OGRCleanupAll() or other similar funcitions that
tear down the environment should only generally be done on application
exit, not cleanup of a single thread.
Best regards,
