[gdal-dev] The use of geometry_columns of the Pg driver
Dylan Beaudette debeaudette at ucdavis.edu
Wed Nov 12 13:34:16 EST 2008
On Wednesday 12 November 2008, Even Rouault wrote:
> For those interested, I've commited code based on Ari's patch to support
> tables with multiple geometry columns. See ticket 1476 and/or updated PG
> driver documentation for the details
This would be a very useful addition for my work!
Thanks!
Dylan
> Le Wednesday 12 November 2008 10:38:28 Ari Jolma, vous avez écrit :
> > Open ticket 1476 seems to be discussing this issue.
> > http://trac.osgeo.org/gdal/ticket/1476
> > Ari
> > Ari Jolma wrote:
> > > The Pg driver consults geometry_columns for the list of layers in the
> > > database and for the geometry type of a layer. But it does not consult
> > > it for the geometry column itself. For example:
> > > I have a table "points", which is created with shp2psql and it is fine
> > > with OGR. Then I decide to add another geometry column, which will
> > > contain the points transformed somehow. I can now either add this as a
> > > new entry in the geometry_columns table or edit the existing entry to
> > > have the new column name. In either scenario OGR is by default a bit
> > > lost. I need to use SQL to get an OGR layer of the points with the
> > > new, alternative coordinates.
> > > Should this disregard of column names in geometry_columns be
> > > considered a bug or feature?
> > > Best regards,
> > > Ari
> > > _______________________________________________
> > > gdal-dev mailing list
> > > gdal-dev at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
