[gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
Matej matej at matnet.net
Wed Nov 12 20:15:00 EST 2008
I will reply myself once more (and the last time). I solved the problem with setting the direct path to the bash instead of $(SHELL) in the line
LIBTOOL =       $(SHELL) $(top_builddir)/libtool
This may help someone else too.
Sorry for reposting on the list,
Matej
matej at matnet.net
  ----- Original Message -----
  To: gdal-dev at lists.osgeo.org
  Sent: Thursday, November 13, 2008 1:38 AM
  Subject: Re: [gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
  Hello,
  I have just realized that there is a problem with shell - I don't know why /bin/sh is used instead of /bin/bash:
  gmake[1]: Entering directory `/usr/home/matej/mapserver/gdal-1.5.3/apps'
  /bin/sh /home/matej/mapserver/gdal-1.5.3/libtool --mode=link    g++  gdalinfo.o  \
                  /home/matej/mapserver/gdal-1.5.3/libgdal.la -o gdalinfo
  libtool_args+=: not found
  compile_command+=: not found
  finalize_command+=: not found
  If I run it with /bin/bash, it works. Now where can I set the default shell used in this and other cases?
  Thanks, Matej
  matej at matnet.net
    Sent: Wednesday, November 12, 2008 2:49 PM
    Subject: [gdal-dev] Problem with gdal-1.5.3 and FreeBSD 6.2
    I have a problem with getting gdal to compile on FreeBSD 6.2. My problem is exactly the same as the one described here http://lists.osgeo.org/pipermail/gdal-dev/2007-November/014763.html.
    I run configure with:./configure --with-pg=/usr/local/pgsql/bin/pg_config
    My configure ouput is
    GDAL is now configured for i386-unknown-freebsd6.2
      Installation directory:    /usr/local
      C compiler:                gcc -g -O2
      C++ compiler:              g++ -g -O2
      LIBTOOL support:           yes
      LIBZ support:              external
      GRASS support:             no
      CFITSIO support:           no
      PCRaster support:          internal
      NetCDF support:            no
      LIBPNG support:            internal
      LIBTIFF support:           internal (BigTIFF=yes)
      LIBGEOTIFF support:        internal
      LIBJPEG support:           internal
      LIBGIF support:            internal
      OGDI support:              no
      HDF4 support:              no
      HDF5 support:              no
      Kakadu support:            no
      JasPer support:            no
      ECW support:               no
      MrSID support:             no
      GRIB support:              no
      cURL support (wms/wcs/...):yes
      PostgreSQL support:        no
      MySQL support:             no
      Xerces-C support:            no
      Expat support:             yes
      ODBC support:              no
      PGeo support:              no
      OCI support:               no
      SDE support:               no
      DODS support:              no
      SQLite support:            no
      DWGdirect support          no
      PANORAMA GIS support:      no
      INFORMIX DataBlade support:no
      GEOS support:              yes
      Old-gen python          no
      SWIG Bindings:          no
      Statically link PROJ.4:    no
      enable OGR building:       yes
      enable pthread support:    no
      hide internal symbols:     no
    When building I get a couple of :not found errors, which look like these:
    libtool: link: g++  /home/matej/mapserver/gdal-1.5.3/.libs/libgdal.so -L/usr/local/lib /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so /usr/local/lib/libexpat.so /usr/local/lib/libcurl.so -lssl -lcrypto -lz -Wl,-rpath -Wl,/usr/local/lib
    /usr/lib/crt1.o(.text+0x72): In function `_start':
    : undefined reference to `main'
    gmake[1]: *** [gdalinfo] Error 1
    I can't find any useful idea, I need libtool but I was able to get it to work long time ago on a FreeBSD 6.2 machine.
    I had libtool 1.5 installed and now have 2.2.6, but the error is the same.
    I would be very glad for any help whatsoever,
    thank you in advance, Matej Serc
    matej at matnet.net
    gdal-dev mailing list
    http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081113/ed8ff526/attachment.html
