[gdal-dev] raw x-y-z height map.
Eran Burstain burstain at gmail.com
Thu Nov 13 10:56:29 EST 2008
Hi.
I want to convert a height map (DTED or other format) to simple ASCII file
with X,Y,Z coordinates, supplemental data (datums) should be in separate
file (.vrt), Is there support in such a format ?
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081113/2cbfc229/attachment.html
