[gdal-dev] raw x-y-z height map.
Roger André randre at gmail.com
Thu Nov 13 14:22:23 EST 2008
There is a gmt utility named grd2xyz that you might be able to use for this:
http://gmt.soest.hawaii.edu/gmt/doc/html/grd2xyz.html
On Thu, Nov 13, 2008 at 11:02 AM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Eran Burstain wrote:
>> Hi.
>> I want to convert a height map (DTED or other format) to simple ASCII file
>> with X,Y,Z coordinates, supplemental data (datums) should be in separate
>> file (.vrt), Is there support in such a format ?
> Eran,
> No, there is currently no direct support for such a format in GDAL.
> The gdal/swig/python/scripts/gdal2xyz.py script will produce such a file
> but it is not then readable with GDAL, nor can it be referenced from a .vrt
> file.
> I do frequently use the AAIGRID driver to produce easy to read ascii files,
> but it does not produce x/y values for each pixel.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam<http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20081113/c2b214d5/attachment.html
