[gdal-dev] nitf xbands supported?
Thu Nov 13 19:53:21 EST 2008
Sarah Mulholland wrote:
> In looking at the NITF 2.1 spec, I notice that the number of bands
> (NBANDS) in an image is by default represented by an ascii charactacter
> ‘0’ to ‘9’.  There’s an XBANDS field that you can use for images with
> more bands when there are multispectral bands in excess of 9.
> I notice that when I call “driver.Create” with more than 9 bands, python
> seg faults when I call GetRasterBand for the first band.  Would I be
> correct in assuming that gdal doesn’t support the XBANDS feature in the
> NITF?
Sarah,
That would appear to be the case.  I encourage you to file a ticket
on the issue.
Best regards,
