[Gdal-dev] problems warping a netcdf file
edfialk wef1 at cec.wustl.edu
Fri Nov 14 12:06:55 EST 2008
Hello, I'm fairly new to reprojection and my experience with gdal is limited,
so I'll do my best to keep up.  I have tried searching through a number of
messages without finding anything quite like my problem.
I've been completely unsuccessful trying to reproject a netcdf file for some
time now and I'm becoming fairly desperate for some help.  I'm going for
changing "Lambert Conformal with a perfect sphere geoid with earth
radius=6370km centered at 40N, 97W with standard latitudes at 33N, 45N to
geographic lat, long (flat) projection."
First, a little gdal info on one particular subdataset for the netcdf file:
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
Driver: netCDF/Network Common Data Format
Size is 148, 112
Coordinate System is `'
ad then coordinates, cdate, ctime, xcent, ycent, etc. etc.  I was wondering
if NC_Global or the coordinate system being `' might cause a problem.
and then, running the command (going to mercator just to get a successful
reprojection, I'll deal with lat/lon later):
gdalwarp -s_srs "+proj=lcc" -t_srs "+proj=merc" NETCDF:"test_0910.nc":PM25
NETCDF:"test_out.nc":PM25
gives me:
ERROR 1: Unable to compute a transformation between pixel/line
and georeferenced coordinates for NETCDF:test_0910.nc:PM25.
There is no affine transformation and no GCPs.
I'm fairly stuck.  If anyone has any ideas at all, I'd really appreciate it.
Thanks!
-Ed
View this message in context: http://www.nabble.com/problems-warping-a-netcdf-file-tp20504569p20504569.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
