[gdal-dev] Compile with ECW: library error
Richard Chirgwin rchirgwin at ozemail.com.au
Mon Nov 17 17:13:29 EST 2008
I'm a Grass-GIS user with a problem in GDAL 1.5.2.
Folllowing the instructions here:
http://trac.osgeo.org/gdal/wiki/ECW
I added ECW support with the ER Mapper library.
The libecwj2-3.3 configure > make > make install reported no errors.
The GDAL configure using --with-ecw=/usr/local/lib went fine, and in the
"supported formats" output we have:
ECW support:               yes
Make and make install complete successfully.
However, when I try to run anything, a libNCSEcw.lib.so error happens:
gdalinfo --formats|grep ECW
gdalinfo: error while loading shared libraries: libNCSEcw.so.0: cannot
open shared object file: No such file or directory
libNCSEcw.so.0 exists in /usr/local/lib
The machine is on OpenSUSE 10.3.
What did I miss in the configuration?
Richard C
