[gdal-dev] gdal 1.5.3 make - files missing
Gong, Shawn (Contractor) Shawn.Gong at drdc-rddc.gc.ca
Tue Nov 18 13:48:40 EST 2008
hi list,
I have made gdal 1.5.3 using the stable branch
http://download.osgeo.org/gdal/daily/
After "make install", libgdal.so.1.12.3, libgdal.la, libgdal.a were
generated in /local-install/lib/
However compared to my previous gdal 1.4.0, these files are missing
under /local-install/lib/python2.5/site-packages/:
osr.py, ogr.py, gdal.py, gdalconst.py, gdalnumeric.py, _gdalmodule.so,
_gdalmodule.la, _gdalmodule.a
What did I do wrong?
thanks,
Shawn
-----Original Message-----
[mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Frank Warmerdam
Sent: Tuesday, November 18, 2008 12:41 PM
To: Gong, Shawn (Contractor)
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] gdal 1.5.3 make error - HDF 4 conflicting
typesfor`UNKNOWN'
Gong, Shawn (Contractor) wrote:
> Thank you Frank and Andrew Brooks.
> Following your leads, I went to check the ticket #2609 and the nightly
> snapshot of the 1.5 branch.
> I have two questions:
> 1) Is http://download.osgeo.org/gdal/daily/ always the latest update
on
> the last public release (currently 1.5.3)?
Shawn,
The trunk and stable branches are captured each night and placed in this
location. So you can always grab essentially the latest code from there.
> 2) I'd like to use latest Rsat2 and TerraSAR-X drivers. Can I
overwrite
> the 1.5.3 with the drivers from 1.6 beta (by copying the entire
> sub-directory)?
This will almost certainly work fine.  But you might also consider just
using the trunk version from svn or the nightly snapshot.  Certainly we
would appreciate your trying it out before the final 1.6 release.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
gdal-dev mailing list
http://lists.osgeo.org/mailman/listinfo/gdal-dev
