Gdal Bug? was: Re: [gdal-dev] JP2MRSID Issues
Tue Nov 18 19:10:36 EST 2008
Michael P. Gerlek wrote:
>> int sceneWidth  = (int)(nXSize * maxWidth / (double)maxWidthAtL0 + 0.99);
>> int sceneHeight = (int)(nYSize * maxHeight / (double)maxHeightAtL0 +
>> 0.99);
> Ouch, you shouldn't be doing rounding like that.  Use the getDimsAtMag()
> function to get the exact width/height you need and all will be well.
Michael,
I have reviewed the documentation for LTIImage:getDimsAtMag() and it appears
to just return the size of the whole image at a particular magnification level.
The above calculations are intended to find the size of the RasterIO() request
window at the desired zoom level.  So I don't think it is applicable.
I have filed a ticket on the problem I found (which happens to have also been
responsible for a bug reported by a client this week) and I have committed
a fix in 1.5 and trunk.
   http://trac.osgeo.org/gdal/ticket/2689
Best regards,
