[gdal-dev] "gdalwarp -te " units of source or target srs?
Wed Nov 19 18:39:53 EST 2008
Matt Wilkie wrote:
> Thanks Even and Frank, you are right I had the order of the coordinate
> pairs backwards, Upper-Left Lower-Right instead of L.Left U.Right. I'm
> used to using gdal_translate -projwin which uses the former. Is there
> any hope of harmonizing the parameters across the utilities so they all
> use the same order?
Matt,
I am concerned that the cure (harmonizing) would be worse than the
disease due to breaking existing scripts.
Best regards,
