[gdal-dev] are libgeos.so and libgeos_c.so needed
Fri Nov 21 11:48:31 EST 2008
Gong, Shawn (Contractor) wrote:
> hi list,
> Are libgeos.so and libgeos_c.so needed in building gdal and its
> dependency libraries?
> If they are needed, where can I download the source code to
> build/include it in the gdal package?
> I am running Linux and Solaris 9.
Shawn,
GEOS is not a required dependency of GDAL/OGR; however, a number of additional
capabilities within OGR become available when built with GEOS.  GEOS can be
found at:
   http://geos.osgeo.org/
If you don't know of a specific reason you need it, I'd be inclined to leave
it out.
Best regards,
